RS2OOO
Hi all,
I hope you have all been well since my last post around 9 years ago!
Back in 2011 with some help from this forum, I purchased the 3rd gen PC spec pasted below. The machine is in use for around 10 hours per day, averaging 6 days per week, and has been every day for the last 11 years with zero issues whatsoever.
It has been an absolute joy to use, with the only change in that time being an upgrade to larger SSDs. In short, it is perfect, and has been ultra reliable.
The only things I think I got wrong with this build, despite rarely using the machine for gaming, is that after a couple of years I almost certainly felt I'd under-specced the GPU. Possibly I over-specced the Motherboard, so maybe I should have used a cheaper Motherboard and a better GPU.
Here is that original spec:
COOLERMASTER SILENCIO 550 QUIET MID TOWER CASE
Intel® Core™i7 Quad Core Processor i7-3770 (3.4GHz) 8MB Cache
ASUS® P8Z77-V LX: USB 3.0, SATA 6GBs, ATI®CrossFireX
16GB KINGSTON HYPERX BEAST DUAL-DDR3 1866MHz X.M.P (4 x 4GB KIT)
1GB AMD RADEON™ HD7770 - DVI,HDMI,DP - DX® 11, Eyefinity 3 Capable
120GB KINGSTON V300 SSD, SATA 6 Gb (450MB/R, 450MB/W)
12x BLU-RAY WRITER DRIVE, 16x DVD ±R/±RW
450W Quiet 80 PLUS Dual Rail PSU + 120mm Case Fan
1 x 12CM Black Case Fan (configured to extract from rear/roof) (£5)
WIRELESS 802.11N 300Mbps PCI CARD (£16)
2 PORT USB 3.0 INTERNAL PCI-EX CARD + STANDARD USB PORTS
Time has come to think about a replacement, budget around the £1500 mark. All I want is an updated version of what I have, and something that will see me through the next 10+ years. It needs to be fast for general use (Over 100 internet tabs open at a time, various work programs running, and good for editing video from time to time, but also usable if I decide to play a game.
I've come up with the following spec, which is a bit over budget so any advice on unnecessary spec would be greatly appreciated, but at the same time, a fast reasonably future proof PC that isn't drawing unnecessary levels of power consumption needs to be prioritised over and above the final price.
Send In Your Own Case
Intel® Core™ i7 12-Core Processor i7-12700KF (3.6GHz) 25MB Cache
ASUS® PRIME Z790-P (DDR5, LGA1700, USB 3.2, PCIe 5.0) - ARGB Ready
32GB Corsair VENGEANCE DDR5 4800MHz (2 x 16GB)
512GB SOLIDIGM P41+ GEN 4 M.2 NVMe PCIe SSD (up to 3500MB/sR, 1625MB/sW)
4TB SEAGATE IRONWOLF PRO 3.5", 7200 RPM 128MB CACHE
RAID
RAID 1 (MIRRORED VOLUME - 2 x same size & model HDD / SSD)
CORSAIR 650W CX-M Series™ SEMI-MODULAR 80 PLUS® BRONZE
PCS FrostFlow 100 RGB V3 Series High Performance CPU Cooler
2 x 120mm Thermaltake TOUGHFAN 12 Case Fans
Creative Sound Blaster® Audigy™ FX
2 PORT (1 x TYPE A, 1 x TYPE C) USB 3.1 PCI-E CARD + STANDARD USB PORTS
PCS BK110 USB KEYBOARD
Price: £1,686.00 including VAT and Delivery
I would be very grateful on any pointers as to where I might be spending money unnecessarily, or where a performance advantage can be obtained for little extra cash, and also for things like the PSU, would a Gold rated 80+ pay for itself in energy savings compared to the bronze?
Finally to note, I will be adding 2 or more additional hard drives so these need accounting for with the power consumption.
RAID
