Help: GPU Upgrade
Nafninja23
Hey all,
I have decided I want to upgrade my graphics card (mostly in preparation for the witcher 3).
My current specs are as follow:
COOLERMASTER CM690 MKII ADVANCED CASE
ASUS® P8Z68-V LX: USB 3.0, SATA 6GBs, ATI®CrossFireX
2GB AMD RADEON™ HD6950 - 2 DVI,HDMI,2 mDP - DX® 11, Eyefinity 4 Capable
Samsung 840 EVO 120GB 2.5 inch Basic SATA Solid State Drive
CORSAIR 650W ENTHUSIAST SERIES™ TX650 V2-80 PLUS® BRONZE
SUPER QUIET 22dBA TRIPLE COPPER HEATPIPE INTEL CPU COOLER
After a bit of research (also similar advice on one of my other posts) it looks as though upgrading to a r9-280x or a gtx 770 would be about right for my system.
However, is there a "best" brand for these?
I almost purchased to Sapphire R9 280X Toxic , but from it's specs it looks like it might be too big for my case (30.8 cm when Coolermaster say 30.4 max on their site) - though I dont know how much difference 4 mm will make - I just dont want to risk it :p.
So, to sum up what gpu would give me the best upgrade with my current spec (including brand as they all seem to vary so much)???
Note: I am willing to upgrade my power supply to if necessary as I've seen some people having issues when buying new cards and not enough power (though if so which one).
