Help! Gaming laptop spec review
Sonny1998
Hello friends. My budget is around £1400 and I'm trying to put together a laptop for some heaving duty video editing in After Effects (and maybe some gaming ie. Cod, Skyrim etc).
I've been told I probably need at least 32gb ram, ideally with a processor from Intel's i7 or i9 series, or AMD's Ryzen 7 or 9. Looking at the suggested laptops on the sales page most have a bit less than 32gb ram, so I've upped it on this configuration. But can I just do that? Do I then need to make sure I've got a processor or a GPU that can keep up? Extra cooling gear? I really have no idea. Would it be simpler to get a desktop instead? Thanks in advance
Ionico Series: 15.3" Matte QHD 240Hz sRGB 100% LED Widescreen (2560x1600)
Intel® Core™ i9 24 Core Processor 14900HX (5.8GHz Turbo)
Get Star Wars Outlaws™ with purchase of qualifying Intel® Core™ 14th Gen Processors
32GB PCS PRO SODIMM DDR5 4800MHz (1 x 32GB)
NVIDIA® GeForce® RTX 4060 - 8.0GB GDDR6 Video RAM - DirectX® 12.1
256GB PCS PCIe M.2 SSD (3200 MB/R, 2700 MB/W)
AC Adaptor
1 x 280W AC Adaptor
Ionico Battery 99WH
PHASE CHANGE THERMAL PAD COOLING (PTM7950)
Bluetooth & Wireless
GIGABIT LAN & WIRELESS INTEL® Wi-Fi 6E AX211 (2.4 Gbps) + BT 5.3
1 x THUNDERBOLT 4 + 1 x USB 3.2 (TYPE C) + 3 x USB 3.2
IONICO 15 SERIES RGB BACKLIT UK KEYBOARD
Microsoft® Edge
Notebook Mouse
INTEGRATED IR+FHD Hybrid Webcam Windows Hello 4.0
Tron1982
Hello
I'll take a look tomorrow if you don't mind, tonight, i have a meeting with Hades 2 :D
