NinjaGinger
So I'm very torn between two PC configurations and I was wondering if I could get your opinions on which is the stronger of the two. My budget is £1300 and I've got two options that are basically at that budget.
Option 1:
Intel Core i5-10600k
RTX 3060 Ti
Noctua NH-U14S (to allow for overclocking)
Option 2:
Intel Core i5-10400f
RTX 3070 (pre order only)
Coolermaster Hyper 212 CPU cooler
(All other specs identical between the two)
I'm trying to decide whether the CPU downgrade is worth the GPU upgrade, mostly interested in gaming above all else. Another thing to note is that the 3070 is pre-order only so I'm not sure how much longer I'd be waiting for it over the 3060 Ti.
Any opinions would be appreciated, thank you.
Option 1:
RTX 3060 Ti
Option 2:
