Help Checking New PC Build
euaedw
I'm recently in need of a new gaming/work PC and have put together an order with the specs seen below. My work involves high-performance 3D modelling and real-time rendering, using software such as Z-Brush, Blender, Maya and Unreal Engine. I have based my order around other people's discussions found online, but I wanted to check myself whether the final design I have made will allow me to continue working, along with playing new/upcoming gaming titles (in 1080p, 144hz) The PC is currently on the high end of my budget, but i could push for £200 more if it would provide a significant boost to the performance/longevity of the machine.
Any help/advice going forward would be amazing!
FRACTAL NORTH TG GAMING CASE (BLACK)
GIGABYTE B650 AORUS ELITE AX V2 (AM5, DDR5, PCIe 4.0, Wi-Fi 6E)
16GB NVIDIA GEFORCE RTX 4060 Ti - HDMI, DP, LHR
Graphics Card Support Bracket
PCS ARGB GRAPHICS CARD SUPPORT BRACKET
CORSAIR iCUE H150i ELITE LCD XT RGB CPU Cooler
LED Lighting
50cm ARGB LED Strip
ONBOARD 2.5Gbe LAN PORT
2 PORT (1 x TYPE A, 1 x TYPE C) USB 3.1 PCI-E CARD + STANDARD USB PORTS
Price: £2,290.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am5-pc/5u8zDbWRDd/
sck451
With your budget I'd be wanting to change the monitor as well and go for 1440p 144Hz at least. Would that be a route you're willing to go down? Honestly this kind of budget for 1080p is a waste.
euaedw
Oh, yes definitely - I just put the 1080 as that is what I currently have at home.
sck451
I'd be looking along these lines, leaving you £350 from your max budget to spend on a really good 1440p monitor.
ASUS® TUF GAMING B650-PLUS WIFI (AM5, DDR5, PCIe 4.0, Wi-Fi 6) Cheaper than the Gigabyte and at least as good
16GB AMD RADEON™ RX 7800 XT GAMING - HDMI, DP - DX® 12 The best value graphics card: ideal for 1440p
512GB SOLIDIGM P44 PRO GEN 4 M.2 NVMe PCIe SSD (up to 7000MB/sR, 4700MB/sW) Smaller boot drive
4TB CORSAIR CORE XT MP600 NVMe PCIe M.2 SSD (up to 5000 MB/R, 4400 MB/W) Maaaaassive games drive (2TB might be sufficient?)
CORSAIR 850W RMx SERIES™ MODULAR 80 PLUS® GOLD, ULTRA QUIET More powerful PSU is generally wise
DeepCool AK620 ZERO DARK High-Performance Dual Tower CPU Cooler Plenty of cooling for the 7800X3D and a lot cheaper than a good AIO
LED Lighting
50cm ARGB LED Strip
MIN. 2 x USB 3.0 & 2 x USB 2.0 PORTS @ BACK PANEL + MIN. 2 FRONT PORTS You don't need extra USB ports: you already have >10
Windows 11 Home 64 Bit - inc. Single Licence If you have a Windows licence you could transfer, it would save £100ish
Price: £2,151.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am5-pc/7DxmBkAtA9/
euaedw
Thank you so much for those suggestions, I had already decided to up the GPU like you said, and those alterations to the SSDs definitely sound good, along with saving some money on the motherboard (admittedly the component I understand the impact of the least). I will be making those changes with the order for sure.
