Help and advice needed!
I am having freeze ups when playing games (only noticed it in WOW to be honest) where I am alt-tabbing and wow "freezes". Its only started doing this in the last couple of months so i thought it might be a Geforce Experience issue but it would appear not. I looked and it seems to be a common issue (by all means correct me if I am wrong) but there seems to be no solution.
Things I have done :
DDU and installed latest drivers without Geforce and without audio.
DDU and installed older drivers without Geforce and without audio.
Removed the RAM sticks and checked them individually
Checked all connections are secure and not broken or showing signs of wear
At this point I am not sure what to do going forward.
The message is below :
The description for Event ID 153 from source nvlddmkm cannot be found. Either the component that raises this event is not installed on your local computer or the installation is corrupted. You can install or repair the component on the local computer.
If the event originated on another computer, the display information had to be saved with the event.
The following information was included with the event:
\Device\Video3
Error occurred on GPUID: b00
The message resource is present but the message was not found in the message table
PC Specs
AMD Ryzen 7 5800X3D Eight Core CPU (3.4GHz-4.5GHz/100MB CACHE/AM4)
ASUS® CROSSHAIR VIII HERO WIFI (DDR4, PCIe 4.0, CrossFireX/SLI) - RGB Ready!
2nd M.2 SSD Drive
2TB SAMSUNG 970 EVO PLUS M.2, PCIe NVMe (up to 3500MB/R, 3300MB/W)
NOT REQUIRED
NOT REQUIRED
CORSAIR iCUE H150i ELITE LCD Display RGB CPU Cooler
NOT REQUIRED
The only thing I have changed on the PC is removed the 1TB NVME and replaced with a 4TB NVME (Same brand Samsung )
Thanks in advance and oh Happy New Year !
Sorry for the late reply. I read up about MSI afterburner and did what people suggested by tweaking the Core Clock and Memory Clock by -30% and the freezes stopped. I also updated the bios so things are somewhat more stable now.
Thanks for your input and help though, its very much appreciated !
