Ok so in @KippleKat thread on the medium it was suggested that I get a headset, so i've started this post for recommendations rather than hijack her thread, so on that post the following were mentioned:
@SpyderTracks
For me, I’d always recommend the Steelseries Arctis 7, such good value and perform as well as headsets costing significantly more, also 24 hour battery life which is very good, and can be used wired if required. (@Nursemorph seconded these)
@Steveyg
I like the Corsair HS70 Pro's 7.1 personally, but the Steelseries stuff is generally very good as well
Sennheiser if you can afford them are second to none though
I've also had a look at these
So any other recommendations?
Cheers in advance
@SpyderTracks
@Steveyg
Corsair VOID ELITE RGB Wireless Gaming Headset (7.1 Surround Sound, Low Latency 2.4 GHz Wireless, 40ft Wireless Range, Customisable RGB Lighting, Durable Aluminium with PC, PS4 Compatibility) - Black
Cheers in advance
