Hardrive operating system
Nickosaurus
Hi guys
I just made an ammendment to my order to have a 2nd hardrive installed... I want my OS to be installed on the 2nd hardrive (NOT the first).
Is there any way I can change my order to have the operating system installed to the 2nd hardrive online? Or will I need to call customer support.
Nickosaurus
Oh you dont happen to know the difference in noise between the black and green caviar hardrives do you?
is it noticeable?
Nemesis
I dont
This is your spec right :
Overclocked CPU
Overclocked Intel® Core™i5-2500k Quad Core (3.30GHz @ max 4.60GHz)
ASUS® P8P67 PRO (NEW REV 3.0): USB 3.0/SATA 6Gb/s, CrossFireX™ & SLI
4GB KINGSTON HYPER-X SPECIAL EDITION GREY - DDR3 1600MHz (2 x 2GB KIT)
1.25GB NVIDIA GEFORCE GTX 570 - 2 DVI,mHDMI - DX® 11, 3D Vision Ready
CORSAIR 850W TX SERIES (TX850) 80+ ULTRA QUIET PSU (£99)
COOLIT ECO A.L.C (ADVANCED LIQUID COOLER) (£49)
ARCTIC COOLING MX-3 HIGH THERMAL CONDUCTIVITY COMPOUND (£9)
Windows 7 home premium
If so then your HDD will be one of the quietest parts there, The GPU and PSU fans will most likely be louder as well as the case fans..... SO i wouldnt worry about the HDD noise
Nickosaurus
ok that helps :)
Thanks again man
and yes thats my system :)
added an extra 4 gig of ram as well and silver warranty :)
