StuWar
Hello
Thanks in advance for your tips.
My new PC has just arrived from PCS and well excited to set it up.
I have a 256GB M.2. drive for Windows and Programmes + a 1TB for my files.
My plan is:
1) Partition the M.2 Drive into C: for windows and D: for programmes
Currently windows as installed is using 45GB of the 256GB.
What do you think I should leave for windows? 80GB? 100GB?
2) Change user files location E: (The 1TB SSD)
It looks like a manual process to move the User files currently at C:/users to E:/users
e.g. https://www.windowscentral.com/how-move-default-user-folders-new-drive-windows-10
And also not sure if this will work for the hidden AppData which on previous computers seems to be ever growing
Do you know if there is a quicker or better way please?
3) Cloaning my set up - so I can go back to a clean install should I need to do so in future.
I'd love to hear your feedback on the above and let me know what you think and if there's a better way to do it.
My plan is:
