Hard drive problem on PC just returned from RMA for different issue
I just had my PC returned this morning from PC Specialist after having the cooling system replaced
The PC boots and all seems fine except now Windows tells me I have 2 hard drives instead of the 3 I had before.
The 3 hard drives I should have:
1x
4TB CORSAIR CORE XT MP600 NVMe PCIe M.2 SSD (up to 5000 MB/R, 4400 MB/W)
(Drive C)
2 x
20TB SEAGATE IRONWOLF PRO 3.5", 7200 RPM 256MB CACHE
(Drives D & E)
Now Windows finds the SSD (drive C) and only 1 of the Seagate HDD's (drive D).
Drive E is not listed.
I've looked up Disk Management in the Computer Management app and it also only finds 2 drives.
I heard some odd clicking noises the first time I booted the PC up on reconnecting it but I don't know if that's relevant.
I generally know my way around PCs but I'm not a computer expert. Feeling pretty down about all this too, I bought this PC as a treat to myself and I've already had to return it twice in 10 months due to 2 failed cooling systems. Having something new wrong with it the day I get it back is really the last thing I needed.
Thank you if you can help.
This is regarding order 2763001 & RMA 123547.
Full specs
Intel® Core™ i7 20-Core Processor i7-14700K (Up to 5.6GHz) 33MB Cache
ASUS® PRIME Z790-P (LGA1700, DDR5, PCIe 5.0)
32GB Corsair VENGEANCE RGB DDR5 5600MHz (2 x 16GB)
12GB NVIDIA GEFORCE RTX 4070 SUPER - HDMI, DP, LHR
2nd Storage Drive
NOT REQUIRED
***** CORSAIR iCUE H115i ELITE CAPELLIX XT RGB High Performance CPU Cooler *****
FAILED & REPLACED WITH
CORSAIR ICUE LINK TITAN 360 RX RGB HIGH PERFORMANCE CPU COOLER
(RMA 123547)
WIRELESS INTEL® Wi-Fi 6E AX210 2,400Mbps/5GHz, 300Mbps/2.4GHz PCI-E CARD + BT 5.0
Microsoft® Edge
Welcome Book
PCSpecialist Welcome Book
Thank you. I had tried to take a look at the drives but struggled to find an easy way to get at them. The case I have lets you look at the motherboard easily enough but not so much the drives. I did eventually manage to partially uncover them though and you were correct - the connector had come out of the hard drive, The cable is squeezed around a corner a bit tightly and I think the plastic of the connector is damaged but it does seem to be working ok now it's plugged in. A great relief, cheers.
Just in case this is misconstrued after the fact, @kevint1972 these last responses weren't aimed at you, there was a clear bot that snuck in posting drivel after you'd found the solution, it's important to tumble on the bots lest they realise the inevitable judgement day
Gawd bless them mods for their swift justice!
