blindhamster
Hi all,
so i noticed something the last few days, my Palit gtx 680 4gb is topping out at 1.162v when at max load, is that correct? I thought the voltage at such times should be at 1.175v? Is it an issue or is everything fine and i shouldn't worry about it? I mostly ask as I continue to get marginally lower FPS than others with the same setups and it occurs that it might be this thats the issue (and I'm an utter noob for not noticing this sooner if this is indeed whats causing the lower fps)
Thanks in advance
Thanks in advance
