great gaming laptop
A few days ago I received my assembled laptop. The order arrived in a well protected and easy to open package. Inside, apart from the computer of course, there was a welcome booklet with useful tips on operating and maintaining the PC. The computer is very thin and light, but at the same time it also has a robust look. Windows 10 was already installed as the operating system, so from unboxing to using it took just a few minutes to set up. Google Chrome was already installed, just as I had requested. I'll be doing extensive gaming tests over the next few days to see how it performs under intense working conditions, but as a first impression I'm definitely satisfied. From placing the order to delivery of the same took about 10 working days, an acceptable wait, but it is good to take into account if you urgently need to receive the product quickly.
Here's my specs:
Telaio e displayIonico Series: Widescreen 165 Hz sRGB 100 % LED opaco QHD 15,6" (2560 x 1440)
Processore (CPU)Processore AMD Ryzen™ 9 5900HX 8 core (3,3 GHz, 4,6 GHz Turbo)
Memoria (RAM)DDR4 SODIMM Corsair 2933 MHz 32 GB (2 da 16 GB)
Scheda graficaNVIDIA® GeForce® RTX 3070 – RAM video 8,0 GB GDDR6 – DirectX® 12.1
1o drive SSD M.2SAMSUNG 970 EVO PLUS M.2 500 GB, NVMe PCIe (fino a 3500 MB/R, 3200 MB/W)
Lettore di schede di memoriaLettore di schede di memoria micro-SD integrato
Adattatore CA1 x Adattatore 230W AC
Cavo di alimentazione1 cavo di alimentazione europeo 1 metro (tipo kettle)
BatteriaBatteria agli ioni di litio integrata (62 Wh) - Serie Ionico
Pasta termicaPASTA TERMICA STANDARD PER UN RAFFREDDAMENTO SUFFICIENTE
Scheda audioAudio alta definizione 2 canali + Jack microfono/cuffie
Bluetooth e wirelessLAN GIGABIT e WIRELESS INTEL® Wi-Fi 6E AX210 (2,4 Gbps) + BT 5.0
Opzioni USB/Thunderbolt1 PORTA USB 3.2 (tipo C) + 3 PORTE USB 3.2
Lingua tastieraTASTIERA ITALIANA RETROILLUMINATA RGB IONICO SERIES
Sistema operativoWindows 10 Home 64-bit – incl. licenza singola [KUK-00001]
Lingua del sistema operativoItalia/Italia – Lingua italiana
Supporto di ripristino WindowsImmagine di ripristino multilingue di Windows 10 - Download illimitati da account online
Software OfficeProva GRATUITA 30 giorni di Microsoft 365® (richiesto sistema operativo)
AntivirusBullGuard™ Internet Security – Licenza gratuita per 90 giorni incl. Gamer Mode
BrowserGoogle Chrome™
Mouse per NotebookMOUSE TOUCHPAD 2 PULSANTI INTEGRATO
WebcamWEBCAM HD 1 MP INTEGRATA
GaranziaGaranzia Oro 3 anni (2 anni Ritiro e reso, 2 anni Ricambi, 3 anni Manodopera)
Consegna3 GIORNI PER LA SPEDIZIONE IN ITALIA
Tempo di costruzioneCostruzione standard – da 8 a 10 giorni lavorativi
Articolo promozionaleOttieni 6 mesi di abbonamento Founders a GeForce Now con laptop RTX serie 30 qualificati
Codice promozionale 4KCuFFjm44cwTbJf74UKr4zz
Libro di benvenutoLibro di benvenuto PCSpecialist - Italia
Hi !
I took the same with the RTX3080 ? It doesn't look exactly the same, I have the Ionico V2 series ! I see you stickers aren't the same and in the place (like the THX one, I have Sound Blaster)
Châssis et affichage
Ionico Series : Écran large LED mat 17,3 pouces 165 Hz sRGB 100 % QHD (2560 x 1440)
Processeur (Unité centrale)
Processeur huit cœurs Intel® Core® i7 11800H (2,3 GHz, 4,6 GHz Turbo)
Mémoire (RAM)
32 Go Corsair 2933 MHz SODIMM DDR4 (2 x 16 Go)
Carte graphique
NVIDIA® GeForce® RTX 3080 - 16 Go de RAM vidéo GDDR6 - DirectX® 12.1
1er disque SSD M.2
1 To SSD PCIe M.2 INTEL® 670p NVMe (jusqu'à 3500 Mo/sR | 2500 Mo/sW)
Pâte thermique
PÂTE THERMIQUE ARCTIC MX-4 EXTRÊME CONDUCTIVITÉ
Carte de réseau sans fil
GIGABIT LAN ET WI-FI INTEL® Wi-Fi 6 AX200 (2,4 Gbps) + BT 5.0
Garantie « pixels morts »
Garantie « pixels morts » de 1 an, frais de main d'œuvre et frais de port compris
I had some issue when starting the first time: I'm not used to install every driver myself with a new laptop (i did it a lot of time with second hand and repair laptop).
Now it looks like it's OK, stable, in games it's ok too :)
