Hi all, got a problem I was hoping you could help a little with, thanks in advance .
My spec has the GTX 670MX, I had to RMA the laptop recently, and during testing PC Specialist found the GPU to be faulty, before this RMA the clock speeds were fine, 601 core and 1399 memory.
Since the RMA frame rate in ALL games has been less than half what it was beforehand, so I checked the clock speeds and they're running at around 185 core, the memory clock is a little higher, and sometimes still reaches the 1399.
I've tried various driver releases to see if this is the problem, the drivers on the Clevo site don't recognise the graphics card so don't install at all.
On a side note all the laptop temperatures have run a bit higher since the RMA.
I've emailed PC Specialist about the issue already but would like a view from this amazing community .
