Good speakers or graphics card upgrade?
Assassin
Hi all. I was just wondering, once I earn a bit more money, would it be best to upgrade a graphics card? (Current one is GTX 670 - I could upgrade to the 690 or get SLI 670s), or should I get some top quality speakers? (Z5500 for example)?
Thanks.
Thanks.
If you are gaming in 1 monitor 1 GTX 670 is plenty for now. Getting a 2nd GTX 670 is cheaper than reselling your used gtx 670 and purchase a gtx 690 that will give you only a very small improvement as opposed to the GTX 670 SLI.
