Going for awesome - laptop
marrob864
What do you reckon to this spec ? Wasn't sure about the SSD/drive caddy option - and wondering whether heat is likely to be an issue.
I'm unlikely to be needing sound system and can use the digital output to drive ext sound system if necessary...
Am happy with Win7 but not convinced about Win8.1
Anyone know if this comes with the chips to support location tracking (eg LoJack) or drive encryption ?
Any thoughts ?
PC Specialist
PCSPECIALIST.CO.UK QUOTATION
The specification below has been formatted so you can easily copy and paste this to our forums when discussing your specification. Once you've copied the specification, please click here to continue.
Vortex Series: 15.6" Matte Full HD LED Widescreen (1920x1080)
Intel® Core™i7 Quad Core Mobile Processor i7-4910MQ (2.90GHz) 8MB
16GB KINGSTON HYPER-X GENESIS 1600MHz SODIMM DDR3 (2 x 8GB)
NVIDIA® GeForce® GTX 880M - 8.0GB DDR5 Video RAM - DirectX® 11
Free Item
FREE £90 IN-GAME VOUCHER with GTX 650 / 750 /7000M / 8000M Series GPUs
Memory - Hard Disk
1TB Samsung 840 EVO SSD, SATA 6Gb/s (upto 540MB/sR | 520MB/sW)
2nd/3rd HDD HARD DRIVE OPTICAL BAY CADDY
Bluetooth & Wireless
GIGABIT LAN & KILLER™ 1202 WIRELESS GAMING 802.11N + BLUETOOTH 4.0
Firewire
1 X 1394a FIREWIRE PORT
2 x 15.6" Vortex Series Battery Pack, 76.96WH (One Spare) (£49)
Power Lead & Adaptor
1 x UK Power Lead & 180W AC Adaptor
Genuine Windows 7 Ultimate 64 Bit w/SP1 - inc DVD & Licence (£139)
INTEGRATED BACKLIT UK KEYBOARD WITH NUMBER PAD
Notebook Mouse
marrob864
Not just gaming... I will also be using it for photoshop, multimedia work, general home office use... keeping the weight down and the speed of boot up/disk management/file transfers...
Budget is not an issue but size/weight is.
If it wasn't for gaming I'd go for a much lower spec for other use - but my experience with laptops (I've had several laptops over 15 years) ius that buying a high-spec results in it lasting longer before needing replacing.
