Hi peeps
Bought a PC from PCS few years back and touch wood (giggity) has been solid since day 1, mostly used for gaming, photoshop and some prem pro.
Over the last 3 months i've noticed the a fan(s?) speeding up intermittently, temps have been fine so didn't think too much of it but today decided to check it out.
Turns out the gfx card fan is not spinning and then suddenly goes into turbo mode for about 20 secs and then stops spinning again, mostly during gaming.
I can't remember this happening in the past and pretty sure the fan would normally spin constantly albeit not in a turbo mode!
Is this a sensor issue on the card or likely a software issue or a bios setting?
any advice appreciated.
Chris
Chris
