Hey
So I've ordered my PC and I wanted to know what kind of settings it will run COD 4 on. By the way its not ment to be a gaming machine and I wanted to stick with Intel as from what I've read Intel is better in the long run.
Also I was wondering if I should get COD 4 on Disc or from Steam and what are the benefits?
If there is anything you think I should know about PC Gaming then posting it here would be great thanks!
My Build:
ANTEC NINE HUNDRED TWO - UK, The Ultimate Gaming Case, Evolved
Intel® Core™i5-760 Quad Core (2.80GHz, 8MB Cache) + Turbo Boost
ASUS® P7P55 LX: USB 2.0 & SATA 3.0Gb/s, CrossFireX™ SUPPORT
4GB KINGSTON HYPER-X BLU DUAL-DDR3 1600MHz, X.M.P (2 x 2GB KIT)
1GB NVIDIA GEFORCE GT430 - DVI,HDMI,VGA - DirectX® 11
500GB SERIAL ATA 3-Gb/s HARD DRIVE WITH 8MB CACHE (7,200rpm)
INTEL SOCKET LGA1156 STANDARD CPU COOLER
My Build:
