getting fewer frames after an in-game stress test
bozzerz
a while ago, I was playing Valorant with a friend. we thought it would be funny to see how many abilities we could put in one location with the aim to crash the game. I thought this was harmless but I don't think it is. Since we did that, my pc has been getting significantly fewer frames, going down from about 300 on Valorant to about 150-200. the decreased frames also apply to other games like Battlefield and GTA 5. any help/suggestions would be greatly appreciated. attached is the PC's specs.
Steveyg
Has anything else changed? Doing what you said in Valorant is unlikely to have caused any problems it's more likely a new piece of software that could be causing issues.
Also you could try giving the system a good clean to make sure it's not overheating. A physical clean I mean
bozzerz
I have given the pc numerous good cleans since it happened. The reason i suspect it is due to valorant is that the friend i was playing with is also getting less frames since. it might not be the direct cause but im convinced. is there any way to see any softwares that could cause this?
Can you post your full specs from your orders page so we can see exactly what we are dealing with
Steveyg
Nah mate that wouldn't affect the system. Valorant isn't exactly a demanding game and the 3070 is a powerful card so I doubt it's an issue
They can handle a lot more than that without breaking a sweat, I would monitor your temperatures though as thermal throttling could be the issue?
It's hard to say without more details though I'm basically just throwing things out there at the minute
is that not what i attached in the first message or do you mean something else?
bozzerz
ah i see. here it is
ASUS® PRIME B550-PLUS (DDR4, USB 3.2, 6Gb/s) - ARGB Ready!
16GB Corsair VENGEANCE DDR4 2400MHz (2 x 8GB)
8GB NVIDIA GEFORCE RTX 3070 - HDMI, DP, LHR
512GB PCS 2.5" SSD, SATA 6 Gb (520MB/R, 450MB/W)
CORSAIR 550W CV SERIES™ CV-550 POWER SUPPLY
STANDARD AMD CPU COOLER
Standard Build - Approximately 15 to 18 working days
Promotional Item
Get 1-Year Founders Membership to GeForce Now w/ select RTX Cards
Welcome Book
Logo Branding
PCSpecialist Logo
Promotional Item
Welcome Book
Logo Branding
PCSpecialist Logo
Did you set anything like vsync on in the nvidia driver?
Steveyg
Yeah it could be anything mate so it's really difficult to pin point. Rolling back your computer to before you were having issues may narrow it down
bozzerz
i tried rolling it back and it worked but i now get an error when launching valorant the first time
I launched it again and it worked but the fps is still low. it doesnt seem like the fix for the issue
bozzerz
is there any way i can check that my gpu is fully working? i dont think i installed any kind of software that could make that kind of difference.
Might be worth running a benchmark as described here, then we can see how it's performing compared to similar builds
bozzerz
ive just run the benchmark you recommended. here's how it went:
can you click the compare results online and post the link, also could you run the firestrike benchmark using the same software
