Hi All,
I have one of the above cards in my PC (link included here)
http://www.geforce.com/hardware/desktop-gpus/geforce-gtx-660/specifications
Currently I'm running a single montior via a DVI output (not sure if it's the I or D) to a VGA converter and my current smallish monitor.
I plan to replace this small monitor with 2 of these -->
http://www.amazon.co.uk/dp/B005QVZ7...lid=13O0K4P6E2F2Q&coliid=I24OMQRLDCA1ZP&psc=1
I might strech to 3 -- depending on feedback here and of course budget.
It may seem a bit of a naive question but I believe this card can support upto 4 montiors from the stanard connectors on the card as -->
One Dual Link DVI-I
One Dual Link DVI-D
One HDMI
One DisplayPort
So my quesitons are -->
1) If I go with a 2 montior config which are the best connectors to use ? Both DVI's and do I need any special cables ?
bearing in mind the current cable I have is a DVI-? to VGA conveter ?
Or should I leave my current cable and just use HDMI on the 2nd monitor ?
2) If I do go with the 3 monitor config, I'm guessing it would be 2 x DVI connections and 1xHDMI (leaving the display port spare).
Again would be keen to know the best cableing options and/or order of plugging things in ?
I realise from the desktop I'd need to use the Nvidia config tool and have seen a couple of YouTube vids how to do this but they don't really touch on the physical set-up and cables.
Thanks in advance - sorry if I am being naieve just not had the luxery/option before to have multiple montiors.
Btw -- this is not for gaming, this is on a rig, used for General purpose and video editing and I basically need more screen real estate, hence why maybe 2 monitors would be enough.
Hope some one can help ?
One Dual Link DVI-I
One Dual Link DVI-D
One HDMI
One DisplayPort
