Gaming/Streaming Desktop PC
Nessy86
Hi I'm looking into a buying a custom PC from PC specialist it will be mainly be used for gaming and streaming to twitch, my budget is £2000 and I will need a OS but I do not need any extras such as monitor as I have those already. I would really appreciate any advice on specs or build.
Then potentially something along these lines: https://www.pcspecialist.co.uk/computers/intel-x99-overclocked/
COOLERMASTER CM690 III ADVANCED CASE (GREEN)
Overclocked CPU
Overclocked Intel® Six Core i7-6850K (3.6GHz @ up to 4.3GHz)
ASUS® X99-A II: ATX, USB 3.1, SATA 6 GB/s, RGB Ready
16GB HyperX SAVAGE DDR4 3000MHz (4 x 4GB Kit)
8GB NVIDIA GEFORCE GTX 1070 - DVI, HDMI, 3 x DP - GeForce GTX VR Ready!
FREE FOR HONOR or GHOST RECON: WILDLANDS with select GTX 10 Series GPUs!
1[SUP]st[/SUP] Hard Disk
M.2 SSD Drive
256GB SAMSUNG SM961 M.2, PCIe NVMe (up to 3100MB/R, 1400MB/W)
NOT REQUIRED
CORSAIR 650W CS SERIES™ MODULAR 80 PLUS® GOLD, ULTRA QUIET
Corsair H100i V2 Hydro Cooler w/ PCS Liquid Series Ultra Quiet Fans
£1,700.00
ex VAT
£2,040.00
inc VAT and Delivery
The Intel quad core i7s like the 7700k are generally a bit better and a lot cheaper for gaming, but for streaming the extra cores of the Intel extremes can have an advantage since the CPU needs to encode the video while also running the game.
AMD are expected to launch their Ryzen CPUs imminently (with a couple of weeks) however, and these are expected to offer performance very similar to the multi-core Intel CPUs for much less cash. So you might want to hold fire a couple of weeks and check your options then.
