Gaming Spec feedback?
chrbuc805
Hi Peeps
Getting a new PC shortly mainly for gaming, wanted to get some advice on the spec I've put together below.
I'll be using a 27" QHD monitor. Tempted to get the iiyama GB2760QSU-B1 27"
Any suggestions, good or bad choices?
COOLERMASTER MASTERCASE H500 GAMING CASE
Intel® Core™ i7 Eight Core Processor i7-9700K (3.6GHz) 12MB Cache
ASUS® TUF Z370-PLUS GAMING II: ATX, LGA1151, USB 3.1, SATA 6GBs - RGB Ready
8GB AMD RADEON™ RX 5700 - HDMI, DP - DX® 12
1st Storage Drive (will be adding my own SSDs)
1TB SEAGATE BARRACUDA SATA-III 3.5" HDD, 6GB/s, 7200RPM, 64MB CACHE -
CoolerMaster Hyper 212X (120mm) Fan CPU Cooler Black Edition
LED Lighting
2x 50cm RGB LED Strip
Thanks all :)
Chris
Any specific favourite games?
In general it's not going to be worth going with an i7 + Z390 motherboard + RX 5700 GPU versus an AMD R5 3600 + B450 mobo + much better GPU for the same price. For 1440p 144hz gaming.
chrbuc805
Nothing specific, console gaming at the mo as current pc is unreliable and Long in the tooth.
WoW, COD, rpgs, mmos, playing fallen Jedi atm.
Is it worth considering a 32” monitor 4K? the scaling issues I’ve read have been putting me off...
It's not worth buying a 4k monitor for a PC that won't be powerful enough to run games at 4k on it. You can usually get around UI scaling issues, but yes, it is a consideration.
The sweet spot for gaming currently is 1440p 144hz. Giving you a much higher resolution than 1080p, the smoothness of high refresh rate, while PC components to run games at 1440p high refresh rates are still basically affordable.
1440p 144hz monitors are mainly ~£300-£500 but some start around £220. See:
An AMD R5 3600 CPU will be better value, giving very solid gaming performance for a lot less cash, saving you money towards a decent monitor that will hopefully serve you at least as long as the rest of the PC. And you can add in an SSD too, for faster Windows, program, and game loading times. And since you're going for RGB, you can go with an RGB CPU cooler too.
Get 3 Months of XBOX Game Pass for PC w/ select AMD Ryzen CPUs
Get 3 Months of XBOX Game Pass for PC w/ select AMD Radeon Graphics
Ghost Recon: Breakpoint -OR- Borderlands 3 w/ select AMD Radeon GPUs
512GB INTEL® 660p M.2 NVMe PCIe SSD (upto 1500MB/sR | 1000MB/sW)
NOT REQUIRED
PCS FrostFlow 240 Series RGB High Performance Liquid Cooler
LED Lighting
Price: £1,134.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am4-gen3-pc/5GPYUQw8hC/
chrbuc805
Thanks for the info, so considering dropping the CPU/MOBO as suggested, think i'm going to keep the RX 5700 should be enough for my QHD gaming and will allow me to keep my overall budget under £1300 inc monitor.
Is the PCS frostflow 24 any good? never used watercooling, any maintenance involved? or is a decent traditional cooler just as good?
Will keep the Barracuda as i have to have a drive on there and i already have decent SSDs i will use as main & secondary.
Monitor
IIYAMA G-MASTER GB2760QSU-B1 27"
It's fine, you don't need a particularly powerful cooler for an R5 CPU.
No maintenance required beyond that of an air cooler i.e. periodic dusting.
I suggested the Frostflow 240 RGB as you seemed to be going for RGB. An alternative that is less flashy and perhaps even better is the Cooler Mastre Lite 240
There's no point to the R5 3600x over the R5 3600 performance wise. The difference is beyond negligible. The only reason to get the R5 3600x is if you were going to buy one of the bundled games it comes with anyway at full price :)
Monitor looks like a good pick for the budget
chrbuc805
Thanks for the help Oussebon.
Last thing, I've always liked the idea of an SFF Case but never felt comfortable building one myself (but as i'm not building this one)
Are they worth considering for a gaming build? Space isn't an issue just like the idea of having something smaller.
Spec idea below-
CORSAIR CRYSTAL SERIES 280X RGB GAMING CASE
Gigabyte B450 I AORUS PRO WIFI (DDR4, USB 3.1, 6Gb/s)
Noctua NH-L9i Low Profile AM4, Super Quiet CPU Cooler
50cm RGB LED Strip
They're almost never worth considering, in my opinion.
They're either so small that they restrict what you can put in, or so large that they're barely any smaller than ATX systems - and can still end up limiting what you put in. For instance the Nano S is little smaller than some ATX cases, but despite that Fractal still recommend only the thinnest GPUs should be installed.
If you want a reasonably compact case there are options. You could use the 'Send in your own case' option PCS have and go for the Corsair Crystal 460X or Corsair iCUE 220T to name a couple that spring to mind.
Or the Fractal Meshify C which PCS stock is very compact. The fans are not RGB but you can always swap out the fans.
There are some extremely clever Mini ITX cases, but they do come at a premium due to the research and development costs and low volumes.
A relatively new design that actually acts as a passive cooler is the Streacom DB4
I'm a bit in awe of this case and plan a build around it, probably as a NAS server.
Or the Lian Li TU150 which is a lot cheaper:
chrbuc805
They were the concerns I had.
Always liked Lian Li cases, but PCS have enough case options I don’t think I’ll about sending in my own.
thanks all, think I’ve got enough info to make my decision.
Appreciate the help.
