Gaming Spec Check - Help Please!
Hi, First of all thanks for looking at my post and for sharing your input.
I'm new to the gaming desktop malarkey as i haven't had a desktop for over 8 years or so!
I'm looking at a mid gaming desktop to play games like WOW, CS:GO on ultra settings with a high FPS
Also games like CS;GO, Over watch and Battlefield in the future with good FPS and high settings.
My budget is around £700 and Intel is what ive been guided towards for a Gaming PC.
Would this spec be more than enough for what ive asked above?
Any input or changes to the spec will be very appreciated.
InWIN GT1 BLACK GAMING CASE
Intel® Core™i5 Quad Core Processor i5-6600 (3.3GHz) 6MB Cache
ASUS® Z170-P: ATX, LG1151, USB 3.0, SATA 6GBs
8GB HyperX FURY DDR4 2133MHz (2 x 4GB)
2GB NVIDIA GEFORCE GTX 960 - DVI, HDMI, 3 x DP (Special!!)
1st Hard Disk
INTEL STANDARD CPU COOLER
2x 120mm Black Case Fan (configured to extract from rear/roof) (£9)
WIRELESS 802.11N 300Mbps/2.4GHz PCI-E CARD (£8)
Genuine Windows 10 Home 64 Bit - inc DVD & Licence (£79)
Price: £737.00 including VAT and delivery.
Looks decent for what you want it for.
Your case has 3 fans in it as standard though, according to the PC description, so adding 2 more probably isn't going to net you much extra cooling. You'd be better off spending that plus a few extra quid on the Titan CPU cooler.
Worth noting that although WoW favours Nvidia cards very strongly (GTX 960 matching the more powerful R9 380x: http://www.techpowerup.com/reviews/ASUS/R9_380X_Strix/20.html ) AMD's latest gen launches on 29th June for the same kind of price as the 960 and promises to be quite a bit more powerful than the current gen. So you may want to consider that as an option. :)
