Gaming PC
lukeizme
Is this a good gaming pc? i will be playing mw3, bf3, crysis 2, minecraft and other intensive things like photoshop and servers!
And will i get the driver disc as i havent got win 7?
STYLISH PIANO BLACK ENIGMA MICRO-ATX CASE + 2 FRONT USB
AMD PHENOM II X6 1055T (2.80GHz/9MB CACHE/AM3)
ASUS® M5A78L-M/USB3: M-ATX, USB 3.0, SATA 3.0Gb/s
2GB NVIDIA GEFORCE GTX 560 - 2 DVI,HDMI,VGA - 3D Vision Ready
500GB SERIAL ATA 3-Gb/s HARD DRIVE WITH 8MB CACHE (7,200rpm)
STANDARD AMD CPU COOLER
4 x USB 2.0 PORTS @ BACK PANEL (MIN 2 FRONT PORTS) AS STANDARD
Fear
Can you tell us what your budget is as people might be able to come up with a slightly better spec for you, also are you using a single of multiple monitors ?
What driver disc did you mean ? you will get the disc for your motherboard and GPU.
Wozza63
Biblical Poster
drop to a quad core CPU and use the cash for a better case
drop to the 1gb 560 unless you are on high resolutions over 1080p
Wozza63
Biblical Poster
£10 over budget but way better
COOLERMASTER ELITE 310 BLUE CASE - better case for improved cooling, kinda necessary to stop your PC from overheating, id recommend adding fans to the 2 empty slots available (side and front) allowing for improved air flow, you may have an old PC with the right size fans (i think its 80mm slots on the case)
AMD PHENOM II X4 955 (3.20GHz/8MB CACHE/AM3) - BLACK EDITION - no need for 6 core at your budget, its overkill anyway for anyone who gets it and most games only recommend quad core, but very few actually use them yet, its also clocked higher than your chosen 6 core and the next one up from this is only £6 if you can afford it
1GB NVIDIA GEFORCE GTX 560 - DVI,HDMI,VGA - 3D Vision Ready - no need for 2GB unless on high resolutions, this will be fine for 1080p or below
CORSAIR 650W ENTHUSIAST SERIES™ TX650 V2-80 PLUS® BRONZE (£72) - much more reliable PSU and has some space for extra upgrades such as RAM or hard drive, although your mobo only has one space for graphics card so no SLi
SUPER QUIET 22dBA TRIPLE COPPER HEATPIPE CPU COOLER (£19) - very good CPU cooler to allow you to play much longer and allow it to last much longer
lukeizme
ok thanks.. but will this be as future proof as the one i posted?
well i would like the six core so can u tell me the advantages?
lukeizme
ty i prefer the other £35 case thou so will it still have the advantages as the other or does the cooler master own all of them?
