Gaming PC
Badgerhunter
hey, I'm thinking of ordering a new pc from here. I'm pretty sure this spec is good for my budget (£900ish including screen, mouse, keyboard ect.). However i would just like it checked by people who know what they are on about :p. Also, i wondered if someone could help me choose between the PCS Maelstrom T900 case and the NZXT M59 case. (both £59) I've searched for reviews and everything about the 2 cases but can't really find out which one is better for cooling and how easy/hard it is if i wanted to upgrade it in the future and how easy it is to clean out. Thanks everyone!
AMD PHENOM II X4 965 (3.40GHz/8MB CACHE/AM3) - BLACK EDITION
ASUS® M5A87: AM3+ PLATFORM, DUAL DDR3,SATA 6.0GB/s, USB 3.0
2GB AMD RADEON™ HD6970 - 2 DVI,HDMI,2 mDP - DX® 11, Eyefinity 4 Capable
1TB SERIAL ATA 3-Gb/s HARD DRIVE WITH 16MB CACHE (7,200rpm)
800W Quiet 80 PLUS Quad Rail PSU + 120mm Case Fan (£79)
STANDARD AMD CPU COOLER
Gorman
Hi and welcome to the forums, of the two cases the NZXT M59 would probably get my vote.
Rig looks pretty good, i would consider dropping the PSU to a 650w Corsair, thats about it!
Badgerhunter
thanks, i put the psu down to the 650w and it said that it requires 701w to run so I'll probs stay with the 800w. The brand of the psu doesnt make a huge difference does it?
Badgerhunter
ok, what would the difference be between corsair and the normal psus? and would it not be better to get the 750 over the 650 as it recommends it and if i do upgrade it in the future i dont have to fork out extra money for a new psu if needed? its only an extra £12 so I would rather be on the safe side.
TrustMeItsWorthIt
Basically the PSU requirement PCS tell you is with a 20% allowance, this allowance is given for slight variance in power usage as well as degradation of the PSU over time. By buying the corsair your buying a PSU that can take more stress and will degrade slower over time (someone tell me if im wrong) so if you buy the corsair (recommended) it will take more punishment and last longer, that being so you should be more than fine running your system on a 650w corsair PSU
Hope this helped
