Gaming PC Spec
aXe
Hi I'd like someone to take a look and address anything I may have missed.
Purpose: Gaming
Budget: £1850 approx
Monitor: 1080p (with the possibility of 1440p in the future)
A couple of concerns out the gate.
I've heard my chosen processor runs quite hot. Is the cooler good enough?
Also PCS website says that the cooler may have to be front mounted. My chosen case already has front mounted fans so are there issues that can arise from this?
Many thanks.
COOLERMASTER MASTERBOX TD500 V2 MESH ARGB GAMING CASE
Intel® Core™ i7 16-Core Processor i7-13700K (Up to 5.4GHz) 30MB Cache
ASUS® TUF GAMING B760-PLUS WIFI D4 (LGA1700, PCIe5.0, USB 3.2)
12GB AMD RADEON™ RX 6700 XT - HDMI, DP - DX® 12
Graphics Card Support Bracket
PCS ARGB GRAPHICS CARD SUPPORT BRACKET
4TB CORSAIR CORE XT MP600 NVMe PCIe M.2 SSD (up to 5000 MB/R, 4400 MB/W)
CORSAIR iCUE H150i ELITE RGB High Performance CPU Cooler
ONBOARD LAN PORT
Firefox™
Monitor Cables
1.8 METRE GOLD PLATED V2.1 Certified HDMI CABLE
PCS BK110 USB KEYBOARD
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/intel-z690-pc/407UrMZrV4/
sck451
I reckon you can get much better for your money with quite a different system, based around an AMD CPU rather than an Intel one. This will be more efficient, cooler, just as strong in performance, and better value. This system will substantially outperform the one you have there. It will also be more upgradable over its lifetime.
FRACTAL FOCUS 2 ARGB GAMING CASE (BLACK) Good case
AMD Ryzen 7 7700 Eight Core CPU (3.8GHz-5.3GHz/40MB CACHE/AM5) Plenty of CPU for most gaming scenarios. For £94 you can upgrade to the 7800X3D, which would be of benefit in some games and some scenarios
ASUS® TUF GAMING B650-PLUS WIFI (DDR5, USB 3.2, 6Gb/s)
32GB Corsair VENGEANCE RGB DDR5 6000MHz (2 x 16GB) Moving onto DDR5 memory
16GB AMD RADEON™ RX 7800 XT GAMING - HDMI, DP - DX® 12 Much stronger graphics card. Overkill for 1080p, but superb for 1440p
DeepCool AG400 Performance ARGB CPU Cooler Plenty of cooling for the 7700 or 7800X3D
ONBOARD 2.5Gbe LAN PORT
Price: £1,813.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am5-pc/mKvkrPrbTp/
You can then spend the money you save on a much better keyboard! As for the HDMI cable: you should use DisplayPort if you possibly can. If your monitor doesn't support it, that's all the more evidence you need a new monitor....!
Just to point out, the above is suited to 1440p, it would be a tragedy to stick to 1080p for more than a few months, just wasting the GPU.
sck451
And the other thing to mention is that the cost of that build could be brought down further to make buying a new monitor easier if it was helpful.
aXe
Thanks for the input, that all makes sense. I'll also get myself a better keyboard and then early next year a 1440p monitor. (y)
Just a pointer, it's Black Friday shortly on the 24th November and Amazon do offers on a lot of monitors where you can pay in 5 installments without having to take out any credit, makes it far more affordable. You'd be looking at £300 - £500 for a suitable monitor so that would be around £60 a month or so over 5 months.
  • Like
Reactions: aXe
Bhuna50
There is also a couple of Prime days coming up with similar deals to look for and again with 5 x monthly payments.
