Gaming PC need help
Your2EzY
I am interested in buying a gaming pc for around £300 - £400 I love the Vibox green MIDI gaming case or something similar with LED lights. When people walk in and see my PC i want them to go WOW! I dont know much about specs but i would like the PC to run max FPS and high quality 1080p on Minecraft while recording. Also i will be playing other games in the future so i want it to be able to get me good FPS on games. If you could reply telling me what you can do for me i would greatly appreciate it. I have arounr £500 but i need to consider a Monitor and Glass Desk maybe. I am completely new to gaming pcs and would be useless at making my own PC. I would love some help and support and could reward you with a $35 rank on my server. I am looking for a PREMADE gaming pc. I have found one for £299 could someone tell me if the specs are good or bad and if they will do what i want my PC to be able to do.
CPU: AMD (Richland) A10-6800K 4.10GHz (4.40GHz Turbo) Socket FM2 Quad-Core Unlocked Processor
Graphics: Integrated AMD Radeon HD 8670D
RAM: 4GB 1600MHz DDR3 Memory (64GB Supported)
Motherboard: Gigabyte GA-F2A88XM-D3H (Socket FM2+) Micro ATX Motherboard
Audio: Onboard High Definition Audio
Case: BitFenix Comrade Midi-Tower Gaming Case
PSU: 500W Cooler Master 12V Elite Power 500 Power Supply
Optical Drive: LiteOn DVDRW Dual Layer DVD Rewriter (m-Disk Support) 24x DVD±R
Hard Drive: 1TB Seagate Hard Drive
Once again i want my PC to be able to run Minecraft on high setting and 100+FPS While recording. Thank you very much for taking your time to read this i hope you can help me out.
If you know of any other builds or PCs that would match my Criteria for £300-£400 pounds PLEASE leave a link below Thanks! Tom
Yorkmann
Posted this on your other thread:
The graphics are integrated so you probably wont be able to run games on high settings with 100fps while recording. We're not supposed to advise you on PCs from anywhere other than PCS, but integrated graphics just wont do what you want to do. Ideally you will need a bigger budget as even AMD components for a gaming rig cost <£300
EDIT: Sorry, is your spec from this website? My mistake if it is.
Your2EzY
Yes it is Thanks, Can u find a PC that Suits my price and would get 100+FPS on Minecraft while recording and will Render videos on HD Thanks.
Your2EzY
Is this any better? would it get 100+FPS on Minecraft while recording and will Render videos on HD, Thanks.
CPU: AMD (Piledriver) FX-4350 4.20GHz (4.30GHz Turbo) Quad-Core Unlocked Processor
Graphics: AMD Radeon R9 270 Gaming 2048MB Graphics Card
RAM: 8GB PC3-12800C9 1600MHz DDR3 Memory (32GB Supported)
Motherboard: GIGABYTE AMD 760G Chipset Motherboard
Cooler: AMD Socket AM3+ CPU Cooler
PSU: 430W Corsair Builder Series CX430M Modular 80+ Bronze Power Supply
Yorkmann
For what you want. I'd go with this. You may need to save up a bigger budget for what you want the PC to do.
COOLERMASTER HAF 912 PLUS MID TOWER GAMING CASE
AMD A4-6300 Dual Core APU (3.7GHz) & Radeon™ HD 8370D Graphics
ASUS® A58M-E FM2+ (M-ATX, DDR3, USB 2.0, 3Gb/s)
8GB KINGSTON DUAL-DDR3 1600MHz (1 x 8GB)
2GB AMD RADEON™ R9 270 - DVI, HDMI, DP - DX® 11, Eyefinity 4 Capable
1st Hard Disk
Super Quiet 22dBA Triple Copper Heatpipe AMD CPU Cooler (£19)
Price: £577.00 including VAT and delivery.
Your2EzY
Ok Thanks, Is Their anyway u could make this cheaper to around ... £400.00.
Yorkmann
For what you want you will need to spend around that figure (£550) minimum. PCS is already cheaper than a lot of places and I doubt you will find anything significantly cheaper anywhere else. I don't have Skype sorry but if you need help with anything on PCS you're best off asking here.
I'm not going to claim to be an expert but the spec I gave you is the best I can come up with to suit your needs.
Your2EzY
Thanks, Can you take a look at these specs and tell me if they are good and ideal for what i want my PC for?
vanthus
Member Resting in Peace
Sorry,but as these forums belong to pcspecialist who sell custom-built PC's it's not allowed to discuss self-builds or specs from elsewhere.
