Gaming PC ( Intel and Geforce based )
Your opinions please.....
Maximum budget is £1000.00, I'm looking to build an Intel and Geforce based gaming system that will run everything out there at reasonable spec, Battlefield 3 , Diablo 3, Star Wars the Old Republic etc etc.
I think a Quad core processor is an absolute must nowadays ? Could I go AMD quad core?
However I really rate Geforce and want to stick with that.
Intel® Core™i5 Quad Core Processor i5-3570K (3.4GHz) 6MB Cache
ASUS® P8Z77-M: MICRO-ATX, USB 3.0, SATA 6GBs, ATI®CrossFireX
1.25GB NVIDIA GEFORCE GTX 570 - 2 DVI, HDMI, DP - 3D Vision Ready
Price: £891.00 including VAT and delivery.
I'd change the HDD to a caviar black (faster) , get the i5-3550 (k is for overclockling which is not needed for gaming), would be thinking of adding a 2nd gpu in the future?
Not looking to add a second GPU, want reasonable power for a good price now, hence the choice.
I have no intention of overclocking, so I'll look at dropping the "K" suffix.
Any other observations ?
Ta :)
Better case for better air cooling/cable management (perhaps PCS maelstrom t900 or the coolermaster 690 II), samsung 1333Mhz would also be ok.
COOLERMASTER CM690 MKII ADVANCED CASE
Intel® Core™i5 Quad Core Processor i5-3550 (3.3GHz) 6MB Cache
ASUS® P8Z77-V LX: USB 3.0, SATA 6GBs, ATI®CrossFireX
Genuine Windows 7 Professional 64 Bit w/SP1 - inc DVD & Licence
Price: £984.00 including VAT and delivery.
Configure Here: http://www.pcspecialist.co.uk/quotes/intel-ivy-bridge-pc/qXPyrJ6tAp/
Wolvo7
Hello, if you can increase your budget by 20 pounds I'd recommend this system. I changed a few things, the most important bit being the GPU. The GTX 670 will max out any game on a single screen and is a lot better than the 570. Also I chose a better case as Ruben suggested, changed the HDD to a caviar black, more reliable and changed the mobo which is a bit better and costs 2 pounds less ^^
Price: £1,020.00 including VAT and delivery.
Configure Here: http://www.pcspecialist.co.uk/quotes/intel-ivy-bridge-pc/tmQzOMmjIz/
Ta :)
If you can afford it go with Wolvo7's suggestion, the GTX 670 would max the games you mentioned and others. :)
