Gaming PC Help
luksla
COOLERMASTER SILEO 500 QUIET MID TOWER CASE
ASUS® P8Z68-V LX: USB 3.0, SATA 6GBs, ATI®CrossFireX
1GB NVIDIA GEFORCE GTX 560 Ti - 2 DVI,HDMI,VGA - 3D Vision Ready
2TB WD CAVIAR GREEN WD20EARS, SATA 3 Gb/s, 64MB (Special Offer)
INTEL SOCKET LGA1155 STANDARD CPU COOLER
Monitor
22" Widescreen TFT 1920 x1080 2MS D-Sub, DVI, 21.6" Panel (£99)
DVI-D & HDMI Monitor Cables
1 x 2 METRE DVI-D CABLE (£5)
LOGITECH® K200 USB MEDIA KEYBOARD (£10)
Mouse
LOGITECH® OPTICAL USB MOUSE (£5)
Speakers
LOGITECH S120 2.0 BLACK SPEAKER SYSTEM (£9)
Price: £973.00 including VAT and delivery.
Was wondering if anybody could give me any advice on if I can improve it while still keeping it under £1000 and I do want the HDD for the large amount of space because I have a lot of files that will be going on it. Thanks.
mantadog
Superhero Level Poster
With a monitor, keyboard and a mouse thats about the best intel/Nvidia build you could get. Only think i would point out on that build is get the 2TB caviar black, the green is a very good storgage drive but the black is better if you only have 1 HDD. Loads the OS and apps super quick, the green will be slightly slower. I always think a good HDD makes the system feel snappy and much better to use.
With the intel build you posted you could upgrade the GPU if needed in the future to give the system a longer gaming life should you wish.
Is your heart set on an intel CPU Nvidia GPU build, or would you look at an AMD setup?
luksla
Monitor
Mouse
Speakers
Price: £975.00 including VAT and delivery.
This is my revised spec. Anyone have any opinions or advice on it?
MadMan
Super Star
Looks good but upgrade the case to at least the coolermaster 310 as you dont want components overheating. You might go over your budget but i'd recommend a corsair power supply for the reliability and energy efficient.
mantadog
Here is a look at an AMD spec for you budget
AMD BULLDOZER QUAD CORE FX-4100 (3.60GHz/6MB CACHE/AM3) More than enough for a good gaming experiance
ASUS® M5A78L-M/USB3: M-ATX, USB 3.0, SATA 3.0Gb/s
1.25GB NVIDIA GEFORCE GTX 570 - 2 DVI, HDMI, DP - 3D Vision ReadyStep up from the 560ti, enough to get you onto high settings on most games
2TB WD CAVIAR BLACK WD2002FAEX, SATA 6 Gb/s, 64MB CACHE (7200rpm) faster HDD for better load speed on everything
STANDARD AMD CPU COOLER
Monitor
IIYAMA E2273HDS 22" LED WIDESCREEN, HDMI/DVI-D 1920x1080 (£139)
Mouse
Speakers
Price: £999.00 including VAT and delivery.
Configure Here: http://www.pcspecialist.co.uk/computers/amd-bulldozer-top-spec-pc/
