Gaming PC first builds Intel and AMD upto £1,200
Hello everyone, would really like your feedback on my builds I've only been looking at making a gaming PC for the past couple of days. I'm happy with my builds but they just need some fine tuning as I am abit of a noob!
My budget is flexible I'm happy to go upto £1,200 if needed, I'd like my pc to be able to play MW3 and BF3. So let me know if I've skimped on anything or need to spend abit more on something in paticular.
Thanks for taking the time to read.
Regards
Phil
Intel
COOLERMASTER CM690 MKII ADVANCED CASE
Intel® Core™i7-2600 Quad Core (3.40GHz, 8MB Cache) + HD Graphics
ASUS® P8P67 (NEW REV 3.0): USB 3.0, SATA 6.0GB/s, CrossFireX™
1.25GB NVIDIA GEFORCE GTX 570 - 2 DVI, HDMI, DP - 3D Vision Ready
CORSAIR 650W TX SERIES (TX650) 80+ ULTRA QUIET PSU (£72)
Price: £1,095.00 including VAT and delivery.
Configure Here: http://www.pcspecialist.co.uk/computers/intel-sandy-bridge-pc/
AMD
COOLERMASTER HAF 922 MID TOWER GAMING CASE
AMD PHENOM II X6 1100T (3.30GHz/9MB CACHE) - BLACK EDITION
ASUS® M5A99X EVO:USB 3.0, SATA 6.0Gb/s, Quad CrossFireX™/SLI™
8GB KINGSTON HYPER-X GENESIS DUAL-DDR3 1600MHz (2 x 4GB KIT)
2GB AMD RADEON™ HD6970 - 2 DVI,HDMI,2 mDP - DX® 11, Eyefinity 4 Capable
CORSAIR 750W TX SERIES (TX750) 80+ ULTRA QUIET PSU (£86)
Price: £1,064.00 including VAT and delivery.
Configure Here: http://www.pcspecialist.co.uk/computers/amd-crossfire-pc/
Teaz
First spec.
Both spec should have no problems playing bf3 and mw3 when they come out but you should go for the intel. the amd spec is a 6 core cpu and isnt really needed since games dont really make use of all 6 cores, just 4 cores.
The intel spec is fine where it stands but if you wish to lower its price then you could go the for 1333mhz of ram as that will have no problems for whatever you do as the speed difference to 1600mhz is not very noticeable as 1600mhz is usually for overclocking along with going for the tripple copper cooler as that will have no probs cooling :)
Well I am going for the Intel
Couple of questions though..
CPU - Shall I stick with 2600 or go with 2600k?
Motherboard - Keep the P8P67 or is there a better one I have over looked?
Power Supply - Do I go with a Corsair 650w?
Let me know your thoughts and also let me know if anything else needs work.
thanks.
ASUS® P8P67 PRO (NEW REV 3.0): USB 3.0/SATA 6Gb/s, CrossFireX™ & SLI
Price: £1,088.00 including VAT and delivery.
Rakk
The Awesome
Only go with the k variant if you are going to be overclocking, since pretty much the only difference between the 2600 and 2600k is that the 2600k is set up for easier overclocking.
So if you're not going to be overclocking go for the i7-2600 and you can easily drop down to the 1333MHz RAM.
If you are, think about the i7-2600k and stay with the 1600MHz RAM
RichH
If your budget allows, I would say go for the corsair psu.
If you need to save a few £ the drop from i7 to i5 as you'll hardly notice any difference if you are purely gaming.
Agree with Rakk ^ about the ram
That system looks very very similar to one I got for my son about 6 weeks ago (the only differences being we got an i5 2500k cpu and a wireless card) and we've had no problems at all running anything on it. The only thing I did notice is that I assume the side fan of the case doesn't fit if you have the triple copper cooler (or if it does, one wasn't fitted to ours) apart from that, the temps stay pretty cool
Teaz
thanks.
You could consider Rakk and RichH's advice with the ram unless you are happy to pay the difference for them?
Stick with the i7 2600 as the "k" is just for big overclocking and overclocking drains the cpu lifespan if you wasn't aware? unless you do have some intentions to? you can still overclock without the "K" but not to mad lengths like the "k".
Both the Pro and standard p8p67 are nearly identical. the Pro just has basically has the extra SLI capability.
Go for the 650w psu if you can as they are alot better and more energy efficient than the traditional standard psu.
Apart from that, the revised spec is good :)
