GAMING PC build help, cheap under £300 for a gift
Kaiser
Hi, I dont really know anything about PC builds. Can someone help me with it? I'm trying to build a gaming pc as a gift for someone under £300?
Thanks a lot guys
Thanks a lot guys
A gaming PC will cost a minimum of about £650 and even that is lower than you want to go.
For that price you'd be better off with a console.
The absolute minimum for a gaming PC might be about £500, and even then you're probably buying something less powerful than a console.
A more plausible entry level gaming system would probably be £550-650, with a mid-range system around £800.
Those prices just for the tower, not for the monitor + KB + mouse. Those would be another £80-100 or so.
For £300 you're probably best off buying your friend a console.
