Gaming PC advice
Thon_Zebra
Hi everyone,
Can you please have a look at my build and provide any suggestions for a good case or alterations I could make here.
This build is purely for gaming on. Thanks!
Budget roughly kept around (£1300)ish.
CORSAIR 275R AIRFLOW TEMPERED GLASS GAMING CASE
AMD Ryzen 7 3800X Eight Core CPU (3.9GHz-4.5GHz/36MB CACHE/AM4)
8GB AMD RADEON™ RX 5700 XT - HDMI, DP - DX® 12
512GB INTEL® 660p M.2 NVMe PCIe SSD (up to 1500MB/sR | 1000MB/sW)
NO RECOVERY MEDIA REQUIRED
Firefox™
Home Installation
NONE
SCOTTISH HIGHLANDS & UK OFFSHORE ISLANDS / N IRELAND
What monitor are you pairing the system with? There are a number of changes that I would suggest but the main one would be the GPU. The next generation Nvidia cards are out now and over the next month or so. In the new line up there is a 3060(Ti) which is going to make the AMD cards look rather silly unfortunately. It's very likely to be priced right where the XT is so I would definitely consider holding off. The 3070, out next month, would be another level again, but would require more budget and be completely dependent on monitor.
Firefox™
Home Installation
NONE
Price: £906.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am4-gen3-pc/bfzPuhBbAb/
Thon_Zebra
Firefox™
Home Installation
NONE
Hi Scott,
The monitor I have is an Acer 1440p with Freesync 144hz. And I know what you mean, makes sense to wait for the new cards to come out.
Just really want to get back to the PC again. Since I have been stuck using an old PS4. Thought about upgrading later down the line.
Hi Scott,
Even if you ordered now with an RTX card, you’d still be waiting around a month for it to be built as this is about the busiest time for years for PCS with the new nvidia cards.
There are new CPU’s being announced on 8th October and the 3060ti is released in October as well, I would strongly suggest holding off til 8th October and ordering then.
