Gaming PC 2k with £1500 budget
MAJ
COOLERMASTER MASTERBOX MB530P RGB GAMING CASE
AMD Ryzen 5 2600X Six Core CPU (3.6GHz-4.25GHz/19MB CACHE/AM4)
Get 3 Months of XBOX Game Pass for PC w/ select AMD Ryzen CPUs
ASUS® TUF X470-PLUS GAMING (DDR4, 6Gb/s, CrossFireX) - RGB Ready!
16GB Corsair VENGEANCE DDR4 2400MHz (2 x 8GB)
8GB NVIDIA GEFORCE RTX 2070 SUPER - HDMI, 3x DP GeForce - RTX VR Ready!
Get Control & Wolfenstein: Young Blood w/ select GeForce RTX GPUs!
256GB INTEL® 760p M.2 NVMe PCIe SSD (upto 3210MB/sR | 1315MB/sW)
NOT REQUIRED
CORSAIR 650W VS SERIES™ VS-650 POWER SUPPLY
PCS FrostFlow 120 Series RGB High Performance Liquid Cooler
Genuine Windows 10 Home 64 Bit - inc. Single Licence [KK3-00002]
Monitor
AOC Q3279VWFD8 31.5" QHD Monitor - 2560 x 1440, 5MS, HDMI, DVI, DP
Speakers
LOGITECH Z313 2.1 SILVER/BLACK SPEAKER SYSTEM
Price: £1,618.00 including VAT and Delivery
hello,
ideally im looking for a PC to run current games such as total war series, hopefully for the next few instalments, and also other AAA games.
£1500 budget but willing to go slightly higher if it warrants the extra hundred or so.
i know i can significantly reduce the price for 1080p gaming but i’m treating myself and wanting to go to 2k.
i’ve basically been running games on a potato for years so i can’t really be disappointed.
RTX 2070 super is punching over your weight for the budget.
I have that monitor, and it's fine, great for what I paid for it, but ideally something with a higher refresh rate and freesync that takes less fiddling to get to work in gsync compatible mode. Furthermore, a better monitor with a wider adaptive sync range will go a long way towards futureproofing as you don't need to worry about keeping over 55fps as much (which is the point at which freesync with Nvidia goes wibbly with this monitor in some titles, in my experience). A 2060 Super is way more than enough.
You should generally expect to upgrade the monitor less frequently than the GPU, so invest a bit more in that instead.
760p SSDs are bad value. You can get an SX6000 with twice the capacity for about the same price. It's just not cheap enough to compete against the cheaper, larger SSDs, or the faster ones like 970 Evo and WD Black.
Faster RAM with a Ryzen CPU.
Stock AMD coolers are fine.
And a 3000 series CPU ideally.
e.g.
NOT REQUIRED
STANDARD AMD CPU COOLER
Price: £1,254.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am4-gen3-pc/Ksv7Zys4ZQ/
Plus upto £350 for a decent monitor.
see https://www.pcspecialist.co.uk/foru...th-august-2019-fusion-fury.64132/#post-445566 for a few pointers
MAJ
awesome thankyou!! as far as i am aware, the CPU isn’t all that important in gaming, as long as you have something as in the quote then you will be fine, am i correct in saying that?
in terms of the 2060 vs 2070, is it worth paying more to future proof? or will the 2060 super be more than adequate to run newer games at 1440p?
Yep :)
Given your limited budget, I do recommend getting a decent GPU and a decent monitor, rather than a high end GPU and a budget monitor.
The CPU can be important, and in view of the performance advantages offered by the 3000 series - which may be particularly relevant when you inevitably come to upgrade your GPU in the future - I'd recommend it.
