Gaming notebook silent
Zottex
Hello,
i will buy soon a notebook for gaming but i have a problem: i must play more silently possible.
so i have choose as cpu an i5 8300 instead of 8750 because in many forums the 8750 is described as many noisy
it is a good choice?
if i choose a i8300 can i undervolt it?
another question: with an i3 8300 is better to choice an gtx 1050 or 1060?
these two cpu are hot when you play?
another question:
if i choose 1050 i can only buy a COSMOS IIV ,
but with the OPTIMUS IX i can choose 1060 or 1050
in case of 1050 qhat i must choose? optimus or cosmos?
thanks
As was said in another topic you posted in, there's pretty well no such thing as a silent gaming notebook.
CPUs and GPUs generate heat. Heat needs to be gotten rid of from the system. This ultimately involves fans. A small chassis like a laptop will have small fans that spin quite quickly and make noise.
The GTX 1050 ti in chassis like the Vyper, Optimus, or Recoil is much, much better than the GTX 1050 in the Cosmos. The GTX 1060 is a lot better still than the 1050 ti.
