Gaming monitor needed for GEFORCE RTX 3060 - HDMI, DP
Hi, I'm currently on the search for a gaming monitor to utilise my GPU capabilities and would like some recommendations for my budget which is unfortunately only £200. I thought about getting the AOC G2460PF which is well within my price range and is 144hz with a 4K UHD 2160p resolution although I'm not too sure if there are better options for my budget. Opinions and recommendations will be greatly appreciated! Thanks.
That monitor is 1080p not 4k. 4k 144hz would cost about £1000
But 1080p 144hz is what you need for your setup, I'd recommend the Mobiuz, it's widely regarded as the best 1080p gaming monitor you can buy
