Hello.
I'm looking to buy a new gaming laptop, and I wanted some advice, and I had a couple of questions as well.
I'm looking at 17'' laptops and the only two options available at the moment are the Vyper and Defiance:
What is the difference between Vyper and Defiance? From what I can tell, Vyper has a bigger battery and a different (presumably better) chassis, while Defiance has USB 3.2, mini-display port (whatever that is). Is that it or is there something major I'm missing? Which of these two would you recommend and why?
I'm seeing that there are some other models as well, e.g. the Optimus model but I can't find any information on it on the website (perhaps because they're out of stock). Are there any models better than Vyper and Defiance?
Both these laptops have backlit keyboards. Can you turn the light off in these keyboards?
This is going to be my first gaming laptop, so if there's any advice or anything that I should consider before purchase then please let me know!
Thanks!
PCSPECIALIST - Custom Computers and Laptops Built to Order
PCSpecialist is a manufacturer of high quality custom computers and laptops. Configure your ideal computer in just a few simple steps with a broad range available.
www.pcspecialist.ie
www.pcspecialist.ie
Thanks!
