jester58th
Hi All
I've been lurking round the forum for a while reading all the posts and checking the advice and have decided on a spec that I'm kinda happy with. So I thought I'd post it here for a little feedback and ask a few questions.
Basically, I need a rig for mainly gaming - Been out of the loop since my last machine died 4 years ago and can't wait to play Skyrim, BF3/4 etc, but also for day-to-day web browsing/multimedia etc. I'm hoping this spec offers decent bang-for-buck and it seems to offer decent upgrade potential (SLI and/or dual monitor)
CM STORM ENFORCER <--Not the case I want, waiting for the CM690 II to be back in stock or maybe the Corsair Vengeance C70. Any thoughts?
Intel® Core™i5 Quad Core Processor i5-4670 (3.4GHz) 6MB Cache
ASUS® Z87-A: ATX, USB2.0, USB3.0, SATA6GB/S, SLi, XFIRE
4GB NVIDIA GEFORCE GTX 770 - 2 DVI, HDMI, DP - 3D Vision Ready <-- Only going to be using 1 monitor for now, but may use 2 later hence the 4gb.
3rd Hard Disk
2TB WD CAVIAR GREEN WD20EZRX, SATA 6 Gb/s, 64MB CACHE
CORSAIR 850W ENTHUSIAST SERIES™ MODULAR TXM-850 V2-80 PLUS® <-- See Below (1)
Super Quiet 22dBA Triple Copper Heatpipe Intel CPU Cooler <-- See Below (2)
WIRELESS 802.11N 300Mbps PCI-E CARD <--*EDIT* Deceided on Homeplugs
Genuine Windows 8 64 Bit - inc DVD & Licence
Miscellaneous
FREE BATMAN: ARKHAM ORIGINS GAME with GTX 660 & 7 Series GPUs!
£1,293.00
(£1,531.00 inc BENQ XL2411T)
Questions
(1) PSU - The config says it only needs a 650w (610w actually) for this setup but I might think about SLIing in the future and the config suggests 1050w for 2 x GTX770 (910w actually) but that's with 20% allowance and it is allocating 300w per GTX770 (which seems too much). In the real world would an 850w be enough?
Even if I don't SLI, I thought I read that it's more efficient to run a psu at 50%-80% max capacity to reduce heat and aid longevity, or did I just dream this up?
(It's only £20 to go from 650w to 850w, but it's another £60 to go to 1050w)
(2) Cooling - I know that for non-overclocked systems the advice is the Triple Copper Heatpipe, but would upgrading to liquid cooling offer any significant longterm advantage?
Probably should add that this machine could be running for 8+ hours a day most days so stability/longevity is very important.
I also need a decent monitor and am thinking about the BENQ XL2411T, if anyone has any thoughts on it.
That's it for now, no doubt I'll think of a few other things but any help or feedback would be appreciated, cheers.
Jester.
3rd Hard Disk
Miscellaneous
£1,293.00
Questions
Jester.
