Gaming config inconsistency
Aleks86
Hello,
I would like to know if among this config, there are incompatibilities on certain components that I do not master well, such as motherboard, sound card, wifi network card, etc ...
Is it if we config something incompatible, we are warned during the recording?
Thanks in advance.
Chassis and display
Recoil Series: 17.3-inch 165Hz 100% sRGB QHD (2560 x 1440) + G-Sync Matte LED Widescreen
Six Core Intel® Core ™ i5-11600K Processor (3.9 GHz) 12MB Cache
RAM memory)
16 GB Corsair 2933 MHz DDR4 SODIMM (2 x 8 GB)
Graphic card
NVIDIA® GeForce® RTX 3060 - 6 GB GDDR6 video RAM - DirectX® 12.1
1st M.2 SSD
500 GB SAMSUNG 970 EVO PLUS M.2, PCIe NVMe (up to 3500MB / R, 3200MB / W)
1st M.2 SSD
Memory card reader
Integrated 6-in-1 card reader (SD / Mini SD / SDHC / SDXC / MMC / RSMMC)
AC adapter
2 AC adapters of 280 W
Power cable
2 Swiss power cable, 1 m (C13 / C14)
Drums
Recoil Series 8-cell (97WH) detachable lithium-ion battery
Thermal paste
STANDARD THERMAL PASTE FOR EFFICIENT COOLING
Soundcard
2 Channel High Def. Audio + SoundBlaster ™ Atlas & Super X-Fi
Wireless network card
GIGABIT LAN AND KILLER ™ WI-FI-AX 1650 M.2 GAMING + BLUETOOTH 5.0
USB / Thunderbolt options
2 x THUNDERBOLT 4 + 1 x USB 3.2 (TYPE C) + 3 x USB 3.2
Keyboard language
GERMAN RGB BACKLIT PER-KEY KEYBOARD
Operating system
Windows 11 Home 64 bits - Single user license included [KK3-00027]
Language of the operating system
France / French Republic - French
Windows recovery media
Windows 10/11 Multi-Language Restore Image - Unlimited downloads from your online account.
Office software
FREE Microsoft 365® trial (operating system required) for 30 days
Anti-virus
BullGuard ™ Internet Security - 90 Day Free User License incl. Gamer mode
Navigator
Firefox ™
Keyboard and mouse
INTEGRATED 2 BUTTON TOUCH PAD
INTEGRATED 1 MP HD WEBCAM
steaky360
Hi @Aleks86
The short answer is yes, if there are incompatible products in your order you would be warned. However to properly answer your question it would be good to know a few things (@Tron1982 already asked previously here: https://www.pcspecialist.co.uk/forums/threads/cohérence-config-gaming.85494/)
Budget, Use(s), any desirable requirements (screen size/portability vs power/etc.).
The more info you can provide about what you are looking for, the better the advice you'll receive :)
Tron1982
Hey ! Nice to see you did it in English ^^
What I can already see you may change is :
You don't want bullguard, it's known to cause problems and Windows defender do the job really well ^^
The Intel x210 Wi-Fi card to the job well, so, I'm not sur that the killer one is a must have ;)
And finally, get win10 instead of win11 as it's not really optimized for now ;)
Oh, and last thing, can you post the configuration link please ?
Aleks86
Hi, thanks for the replies.
So to answer your questions :
  • Budget max : 2'500.- CHF (swiss currency), around 2'000 £
  • Use : gaming of course, it will be for the new Battlefield so need a good graphics card and especially for Football Manager, I read on an English forum that it was the processor that was important with a speed of at least 3 GHz and RAM clocked at a minimum of 3000 Mhz.
  • Others : no need for screen, keyboard, etc...
  • Configuration link : https://fr.pcspecialist.ch/configurations-sauvegardées/recoil-V-17/QdDwt6SG6Z/
For Win11, that was my question also, to know if it's optimized or not at the moment, I will change this and remove the wifi card :)
Tron1982
Hey, so
You didn't answers one of my question in your previous thread
Do you really need a laptop instead of a desktop ? (if i'm not wrong, you can have a better set up with a desktop)
If yes, do you really need a Desktop replacement (DTR) instead of a classic laptop ? (more powerfull, but less portability and autonomy, heavier and more expensive (for the recoil))
If yes, do you need a 17" ? Because now, PCS offer a really sweet 15" DTR with an amd cpu (they are better than intel at the moment, and it's less expensive than the recoil)
Edit : I saw you selected the fast track option (and they are worth it), but, if i may, it may be better to improve your spec' instead of paying for the fast track option with the recoil
if your answers at my questions imply that you don't need a recoil anymore, maybe you can keep it ^^
Aleks86
Yes I want a laptop, I no longer want a desktop and no more space at home (with 3 kids).
And yes I prefer a 17" instead of 15", as I plan to play on the laptop and no longer on a nearby screen (23 "or more) I therefore need the maximum size.
The reason why I chose the Recoil is because it's the only laptop model where I can change the processor for something high-performance (and I don't like AMD) I would have liked to put the i7-11700K but I will be off budget then.
And I choose fast delivery because I plan to order at the beginning of November when I receive the salary, Football Manager comes out on November 9 so otherwise I have to wait 3 weeks before receiving it :LOL:
Tron1982
Hello
So, after your answers, this is what i can advice as a minimum :
But, as it's true the cpu can be updated, you should take an highter gpu if you can (the 3070, but it's 300 CHF more expensive)
Châssis et affichage
Recoil Series : Écran large LED mat 17,3 pouces 165 Hz 100% sRGB QHD (2560 x 1440) + G-Sync
Processeur (Unité centrale)
Processeur Six Core Intel® Core™ i5-11600K (3,9 GHz) 12 Mo de cache
Mémoire (RAM)
16 Go Corsair 2933 MHz SODIMM DDR4 (2 x 8 Go)
Carte graphique
NVIDIA® GeForce® RTX 3060 – 6 Go de RAM vidéo GDDR6 – DirectX® 12.1
1er disque SSD M.2
500 Go SAMSUNG 980 PRO M.2, PCIe NVMe (jusqu'à 6900 Mo/R, 5000 Mo/W) => i propose you this ssd because it would be a shame to not use the pcie 4 port at it full capacities
1er disque SSD M.2
1 To SSD PCIe M.2 INTEL® 670p NVMe (jusqu'à 3500 Mo/sR | 2500 Mo/sW) => it's almost as good as the samsung one, but it's bigger for almost the same price
Lecteur de carte mémoire
Lecteur de carte intégré 6-en-1 (SD /Mini SD/ SDHC / SDXC / MMC / RSMMC)
Adaptateur C.A.
2 adaptateurs C.A. de 280 W
Câble d'alimentation
2 câble d'alimentation suisse, 1 m (C13/C14)
Batterie
Batterie lithium-ion détachable à 8 cellules (97WH) série Recoil
Pâte thermique
PÂTE THERMIQUE STANDARD POUR UN REFROIDISSEMENT EFFICACE
Carte son
2 Channel High Def. Audio + SoundBlaster™ Atlas & Super X-Fi
Carte de réseau sans fil
Wi-Fi 6 LAN HAUT DÉBIT ET SANS FIL INTEL® AX210 (2,4 Go/s) + BT 5.0 => for 4 CHF, it's better ^^
Options USB/Thunderbolt
Langue du clavier
CLAVIER PER-KEY ALLEMAND RÉTROÉCLAIRÉ RGB
Système d’exploitation
Windows 10 Famille 64 bits - Licence mono-utilisateur incluse [KUK-00001]
Langue du système d’exploitation
France/République Française - Français
Support de récupération Windows
Image de restauration multi-langue Windows 10 / 11 - Téléchargements illimités depuis votre compte en ligne.
Logiciel Office
Essai GRATUIT de Microsoft 365® (système d’exploitation requis) pendant 30 jours
Antivirus
PAS D'ANTIVIRUS
Navigateur
Firefox™
Clavier et souris
PAVÉ TACTILE 2 BOUTONS INTÉGRÉE
WEBCAM INTÉGRÉE 1 MP HD
Garantie
Garantie or de 3 ans (2 ans retour, 2 ans pièces, 3 ans main d'œuvre)
Garantie « pixels morts »
Garantie « pixels morts » de 1 an, frais de main d'œuvre et frais de port compris
Châssis
Clevo X170KM-G (165Hz QHD, G-Sync, Blank KB)
Livraison
3 JOUR LIVRAISON EN SUISSE => with the brexit, i'm afraid you may pay for nothing ^^"
Délai de construction
EXPÉDITION EXPRESS 5 JOURS OUVRABLES => the 5 days is almost as good as the 3 for less expensive (and in fact, when i choose the 5 days, it was done in 3 ^^)
Prix : CHF 2'585.00, TVA et livraison comprises
URL unique pour reconfigurer : https://fr.pcspecialist.ch/configurations-sauvegardées/recoil-V-17/2UjkUhhUKQ/
on another topic, just for your information, amd is better nowaday than intel (i know there is a topic somewhere on the forum ^^)
Aleks86
I would have liked to take the RTX 3070 but I am out of budget.
I will change the discs right now, thank you for the recommendation ! ;)
@Tron1982 Edit: If I understood correctly, it is possible to send the PC back later to upgrade components ?
Tron1982
A desktop replacement laptop has a desktop cpu socket
So, you can change your "old" cpu with any cpu with the same kind of socket
So, technicaly, you don't have to send it back to upgrade, you can do it yourself
May i ask you if you would consider an other chassis ?
The valeon and the ionico look good and they have an amd cpu that's better than intel
And you would have better spec' for less money
(And if you want to stick to DTR for the upgradability, the destian (even if it's a 15") look amazing for less money too)
I propose, for info, a spec with each if the chassis, with a 3070, 2 1To ssd, and the best cpu available, by, in my opinion, performance order
(and with your other requirements ^^)
Destian Series : Écran large LED mat 15,6 pouces 240 Hz 72 % NTSC Full HD (1920 x 1080)
CPU Six cœurs AMD Ryzen 5 5600X (3,7GHz-4,6GHz/35 Mo CACHE/AM4)
Mémoire (RAM)
16 Go Corsair 3200 MHz SODIMM DDR4 (2 x 8 Go)
Carte graphique
NVIDIA® GeForce® RTX 3070 - 8 Go de RAM vidéo GDDR6 - DirectX® 12.1
1er disque SSD M.2
1 To SAMSUNG 980 PRO M.2, PCIe NVMe (jusqu'à 7000 Mo/R, 5000 Mo/W)
1er disque SSD M.2
Adaptateur C.A.
1 ADAPTATEUR C.A. 230 W
1 câble d'alimentation suisse, 1 m (C13/C14)
Batterie
Batterie lithium-ion détachable à 6 cellules série Destian
Pâte thermique
PÂTE THERMIQUE ARCTIC MX-4 EXTRÊME CONDUCTIVITÉ
Carte son
1 PORT USB 3.2 (Type C) + 2 PORTS USB 3.2 + 1 PORT USB 2.0
Langue du clavier
CLAVIER ALLEMAND DESTIAN SERIES
Logiciel Office
Antivirus
PAS D'ANTIVIRUS
Navigateur
Microsoft® Edge (Windows 10 uniquement)
Clavier et souris
Garantie
Garantie or de 3 ans (2 ans collection et retour, 2 ans pièces, 3 ans main d'œuvre)
Châssis
Clevo NH55VRQ (8GB RTX-3070, 240Hz N7, Blank KB)
Livraison
Prix : CHF 2'181.00, TVA et livraison comprises
URL unique pour reconfigurer : https://www.pcspecialist.fr/configurations-sauvegardées/destian-15/7NXZQ6h4YP/
Valeon Series : Écran large LED mat 17,3 pouces 165 Hz sRGB 100 % QHD (2560 x 1440)
Processeur Huit Core AMD Ryzen™ 9 5900HX (3,3 GHz, 4,6 GHz Turbo)
Mémoire (RAM)
Carte graphique
1er disque SSD M.2
1 To SAMSUNG 970 EVO PLUS M.2, PCIe NVMe (jusqu'à 3500 Mo/R, 3300 Mo/W)
1er disque SSD M.2
Lecteur de carte mémoire SD intégré
Adaptateur C.A.
Un adaptateur secteur 230 W
Batterie
Batterie lithium-ion intégrée de 62 WH série Valeon
Pâte thermique
Carte son
High Definition Audio 2 canaux + prise MIC/casque
1 PORT USB 3.2 (Type C) + 3 PORTS USB 3.2
Langue du clavier
CLAVIER ALLEMAND RÉTROÉCLAIRÉ RGB VALEON 17 SERIES
Logiciel Office
Antivirus
PAS D'ANTIVIRUS
Navigateur
Clavier et souris
Garantie
Châssis
TongFang GM7ZN7M (8GB RTX-3070, R9-5900HX, 165Hz QHD, Blank KB)
Livraison
Prix : CHF 2'326.00, TVA et livraison comprises
URL unique pour reconfigurer : https://www.pcspecialist.fr/configurations-sauvegardées/valeon-17/Yezx79Dpv2/
Ionico Series : Écran large LED mat 17,3 pouces 165 Hz sRGB 100 % QHD (2560 x 1440)
Mémoire (RAM)
Carte graphique
1er disque SSD M.2
1er disque SSD M.2
Lecteur de carte mémoire Micro-SD intégré
Adaptateur C.A.
Batterie
Batterie lithium-ion intégrée de 91 WH série Ionico
Pâte thermique
Carte son
Langue du clavier
CLAVIER ALLEMAND RÉTROÉCLAIRÉ RGB IONICO 17 SERIES
Logiciel Office
Antivirus
PAS D'ANTIVIRUS
Navigateur
Clavier et souris
Garantie
Châssis
TongFang GM7ZN7P (8GB RTX-3070, R9-5900HX, 165Hz QHD, Blank KB)
Livraison
Prix : CHF 2'401.00, TVA et livraison comprises
URL unique pour reconfigurer : https://www.pcspecialist.fr/configurations-sauvegardées/ionico-II-17/88CxJbXebD/
Those 3 options are less expensive and more or less as good, or better, than the recoil
but it's true, with some downside
Those 2 chassis are made by tong-fang (that may be a little less sturdy than clevo chassis) and have a laptop cpu
-the ionico has a really thin chassis, so it may heat more than the other
-the valeon has a unusual screen fixation
This chassis is "only" a 15" 1920x1080 chassis (downside) but (on the good side), it's a clevo made one (their chassis are a little bit better than the tongfang)
But it has a desktop cpu (the amd 5600x) that can be upgraded and also have a pcie4 port and the chassis is 33 mm thick, so i think it will manage heat easily ^^
