Gaming computer
Littletruck
hi guys, using my dads account to check this spec as i'm getting a gaming computer for christmas, however it's coming to over £1200 and really I need to be around £900
Games that I am looking to play are fallout 4, doom, stuff like that on a high setting plus I like to dabble with a little bit of coding and photoshop.
SHARKOON VG4-W GAMING CASE (Green LED)
Intel® Core™i5 Quad Core Processor i5-6500 (3.2GHz) 6MB Cache
ASUS® Z170 PRO GAMING/AURA: ATX, LG1151, USB 3.1, SATA 6GBs, RGB Lighting
FREE MAFIA III game code with select ASUS*® Motherboards!
16GB HyperX SAVAGE DDR4 2666MHz (2 x 8GB Kit)
8GB NVIDIA GEFORCE GTX 1070 - DVI, HDMI, 3 x DP - GeForce GTX VR Ready!
1st Hard Disk
240GB KINGSTON UV400 2.5" SSD, SATA 6 Gb (550MB/R, 490MB/W)
1TB WD BLACK 3.5" WD1003FZEX, SATA 6 Gb/s, 64MB CACHE (7200rpm)
INTEL STANDARD CPU COOLER
Price: £1,287.00 including VAT and delivery.
Unique URL to re-configure: http://www.pcspecialist.co.uk/quotes/intel-skylake-pc/9JVjQ!7TrE/
Thanks, Kat
£900 and a GTX 1070 isn't going to happen pretty much any way you slice it.
A GTX 1060 6gb would handle those games on high settings (at 1080p res). The motherboard is more expensive than you need it to be. You're not overclocking, running SLI, using an M.2 SSD, using a -K CPU or basically making use of any of the features it offers/ is designed around. The faster RAM is nice to have and can have an impact in gaming performance (particularly in FO4 as it happens: http://www.hardwareunboxed.com/forum/viewtopic.php?t=1570 ). A WD black is nice but it's expensive and you can live with a normal HDD very happily.
I'd strongly suggest a better CPU cooler as well.
If you need to start slicing off £££ then something like:
CORSAIR SPEC-03 COMPACT GAMING CASE - RED LED
Intel® Core™i5 Quad Core Processor i5-6600 (3.3GHz) 6MB Cache
ASUS® H110M-R: Micro-ATX, DDR4, LG1151, USB 3.0, SATA 6GBs
16GB HyperX FURY DDR4 2133MHz (2 x 8GB)
6GB NVIDIA GEFORCE GTX 1060 - DVI, HDMI, 3 x DP - GeForce GTX VR Ready!
FREE PARAGON GAME READY PACK with select GTX 1060 Systems!
1[SUP]st[/SUP] Hard Disk
2[SUP]nd[/SUP] Hard Disk
1[SUP]st[/SUP] DVD/BLU-RAY Drive
Super Quiet Titan DragonFly Heatpipe Intel CPU Cooler
Price: £973.00 including VAT and delivery.
Unique URL to re-configure: http://www.pcspecialist.co.uk/quotes/intel-skylake-home-office-pc/kg6FfGWwXR/
With a GTX 1070 it's £1153. I also upped the CPU since photoshop seems to respond quite strongly to single-threaded performance, and changed the case to one that can accept more fans in case you upgrade the GPU in future and need more cooling to go with it.
I kept the UV400 in there but would strongly recommend the HyperX Savage or 850 Evo (better but more expensive) over it.
PCUser1990
If you need to make any further savings you could consider dropping to 8GB of RAM and buying another 8GB later on. You could also consider not getting a DVD drive - assuming you aren't going to be using any CD/DVDs which a lot less people do these days, and once again you can buy either an external or internal one later on.
DVD drive is a good suggestion. :)
If going for the M-ATX build I posted above I'd strongly recommend getting 16gb RAM at the outset as the mobo has only 2 DIMMs, which means that if buying 8gb (2x4gb) now the RAM would need to be replaced in order to upgrade to 16gb later on, which obviously costs you more in the long run.
