Outerarm
It has been nearly 10 years since I bought my last gaming rig and a replacement is now long overdue. My philosophy with my last purchase was to stretch my budget as far as possible and buy something that would not need to be replaced or upgraded each year. This seems to have worked well with new memory, PSU and GFX card the only updates over the years, however I can no longer play the latest generation of titles at high settings and so it is time to buy again.
The primary purpose of the machine will be for gaming, predominately first person shooters. I will also be using the box for digital photo work with some 3D design and rendering tasks, with very occasional film editing and encoding.
Following the same principle that severed well with the last box I bought I’m looking at pushing my budget and aiming for a new rig that will deliver performance for many years to come. I accept that I’ll probably need to upgrade bits, such as add memory and a second gfx card at some point, but hopefully the rest of the rig will not require much change.
With the above in mind, the spec I’m tweaking at the moment is:
Based on the premise that I am looking for a base rig that will last 6 to 8 years without major upgrades what are people’s thoughts on this spec? As the motherboard is SLI compliant and the PSU has enough grunt for a second 690, I can easily add an additional gfx card and upgrading the memory and hard drives should be simple if needed, however am I compromising anything that would limit future upgrades?
I’m also wondering if the choice of motherboard, CPU and 2400MHz memory is a good combination or if I’d be better off dialling back the memory speed and getting more RAM instead.
All opinions welcome -- I’d really like some feedback before committing to a new rig!
Cheers,
OA
- Case: CORSAIR GRAPHITE SERIES™ 600T WHITE MID-TOWER CASE
- Processor (CPU): Intel® Core™i7 Six Core Processor i7-3930K (3.2GHz) 12MB Cache
- Motherboard: ASUS® RAMPAGE IV EXTREME: INTEL X79, SOCKET 2011, R.O.G
- Memory (RAM): 16GB KINGSTON HYPERX BEAST QUAD-DDR3 2400MHz X.M.P (4 x 4GB KIT)
- Graphics Card: 4GB NVIDIA GEFORCE GTX 690 DUAL GPU - 3 x DVI-I, 1 x mDP
- 1st Hard Disk: 240GB KINGSTON HYPERX 3K SSD, SATA 6 Gb/s (upto 555MB/sR | 510MB/sW)
- 2nd Hard Disk: 2TB WD CAVIAR BLACK WD2002FAEX, SATA 6 Gb/s, 64MB CACHE (7200rpm)
- Optical Drive: 12x BLU-RAY WRITER DRIVE, 16x DVD ±R/±RW
- Power Supply: CORSAIR 1050W PRO SERIES™ HX1050-80 PLUS® GOLD MODULAR
- Processor Cooling: Corsair H100 Hydro Series High Performance CPU Cooler
- Sound Card: Creative Sound Blaster Recon3D PCI-E Soundcard
Cheers,
OA
