They already have their own AIOs, the frostflow 120 and 240.This might mean that the product is currently out-of-stock or PCS don't sell it anymore, might be because their bringing out their own AIOs? 🤷♂️ (source: )
Lol, I'm just hoping i dont have to change the cooler because this would be the 5th change ive had to make and the budget I put aside for the system has run dry and I really dont want to have to spend any more money if i dont absolutely have toAh, right. just edited my original message.
I hope so, because the RGB one thats still on there is literally the EXACT same thing just with an rgb fan lmaoI'd assume it'd not change the price. it (in my opinion) should be a free swap-out.
Ok thank you, just wanted to make sure because I wasn't told when the CPU I chose went out of stock and only found out I have to change it after contacting first.Stock is allocated as a first part of the order process. You only need to change a component if PCS have contacted you to let you know it's not available due to supplier issues.
One reason for the lack of notice might be because you're some way back in the queue and they expected a delivery before yours got into building?Ok thank you, just wanted to make sure because I wasn't told when the CPU I chose went out of stock and only found out I have to change it after contacting first.
