cwobritton1875
Hi All,
Just got my PCSpecialist rig on Friday and in the main I'm really impressed, the only niggling thing is the front USB ports don't work. I've checked in the BIOS and all ports are enabled, anyone got any suggestions? Spec is as follows:
Overclocked CPU
Overclocked Intel® Core™i7-4770k Quad Core (3.50GHz @ max 4.40GHz)
ASUS® MAXIMUS VI GENE: RoG, PCI-e 3.0, SATA 3.0, USB3.0, THX
16GB KINGSTON HYPERX BEAST DUAL-DDR3 2400MHz X.M.P (2 x 8GB KIT)
4GB NVIDIA GEFORCE GTX 770 - 2 DVI, HDMI, DP - 3D Vision Ready
4TB WD CAVIAR BLACK WD4001FAEX, SATA 6 Gb/s, 64MB CACHE (7200rpm)
8x BLU-RAY ROM DRIVE, 16x DVD ±R/±RW
CORSAIR 650W ENTHUSIAST SERIES™ MODULAR TXM-650 V2-80 PLUS®
Corsair H80i Hydro Series High Performance CPU Cooler
Overclocked CPU
