Front Audio panel not working?
lewishollings
Hey guys, my front audio panel doesn't seem to be working, when I plug something into the front nothing comes out :/ any help?
kruppsy
Master
Has it ever worked?
You could try motherboard drivers though and also see if its all connected properly.
steaky360
When you plug something into the front does the audio stop coming out elsewhere? If so check its not muted in the windows volume mixer (bottom right hand corner of taskbar click the speaker then click "mixer")
If it doesn't stop the sound coming out elsewhere it could either be a driver issue or it may not be connected, worth checking inside to see if there are cables attached to the rear of the panel.
lewishollings
The audio used to stop coming out of mmy headphones and work with whatever I plugged in but now the audio stays on my earphones and doesn't come out of whatever I plug in :/
