CaptainFreezy
Hi all,
My friend has a problem with his PC that I hope some of you could help with. When he turns the PC on, the lights and fans all come on. However, the cpu fan appears to come on at a very loud level and stays constant at it. Meanwhile nothing displays on the monitor and it eventually goes into power saving.
Specs are I believe as follows
I5-4670K (Stock Cooler)
Gigabyte z-87X motherboard
8GB RAM*** Could this be the problem?
GTX 760
CS650
Steps all ready tried
Replacing all leads to GPU and monitor
Checking lose connections
changing power outlets.
I'm going round on thursday to take a look at it. At the minute I'm wondering about removing GPU and seeing if it displays anything on mobo graphics or changing the mobo slot ram is plugged into (Does anyone think this would actually do anything?)
All tips would be greatly appreciated and very helpful, just like they were when I chose my PCS specs
Thank you
Ally
GTX 760
CS650
Thank you
Ally
