Hi all
I've seen the FRACTAL MESHIFY S2 has come into stock at PCS - can I just verify the size dimensions are correct at: 538 (H) x 233 (W) x 465 (D) mm - or have they got the height/depth sizes mixed up, because the other case FRACTAL DEFINE R6 BLACK which I was considering is 465 (H) x 233 (W) x 543 (D) mm and it's by the same manufacturer?
I'm only asking because I need it to fit into my desk pedestal area and 538 mm in height might be too tall for it to fit into.
Many thanks
Many thanks
