FN Key not working
Solljak
I bought a recoil laptop which arrived, everythings looking good other than the fact that i cant getthe FN key to work. I press and hold to turn get access to volume up and down but nothing. I need this buttong to work as for my job i need access to the page up / down feature.. Anyone got any suggestions on what the issue may be?
I have youtube'd how to switch the FN key on which directed me to looking into the BIOS settings but the BIOS seems really bare bones, or i just couldnt see the option.
Please help!!
Please help!!
Can you post your full specs from the order page?
Solljak
Recoil Series: 15.6" Matte QHD 165Hz sRGB 100% LED Widescreen (2560x1440)
AMD Ryzen™ 9 Eight Core Processor 5900HX (3.3GHz, 4.6GHz Turbo)
16GB Corsair 2933MHz SODIMM DDR4 (2 x 8GB)
NVIDIA® GeForce® RTX 3070 - 8.0GB GDDR6 Video RAM - DirectX® 12.1
AC Adaptor
1 x 230W AC Adaptor
Recoil Series Integrated 94WH Lithium Ion Battery
1 x USB 3.2 PORT (Type C) + 3 x USB 3.2 PORTS
PER-KEY RGB BACKLIT UK MECHANICAL KEYBOARD
Firefox™
INTEGRATED 1MP HD WEBCAM
Dead Pixel Guarantee
Promotional Item
Get 6 Months Founders Membership to GeForce Now w/ select RTX 30 Series Laptops
Welcome Book
Has it got gaming center installed? Should be in running programs in the up arrow of the taskbar? It’s a master driver.
Solljak
i can't see gaming center? can this be downloaded? I did check for updates but it didnt do any.. i will double check now
Gaming center (also possibly called control center) should be available in your online account in the downloads section if it’s not installed.
That’s what governs the hot keys along with fan profiles, power profiles and most things.
Solljak
And just to confirm, have you applied all windows updates including optional ones?
Updating now
Oh my god i think i love you.
This solved my issue thank you!
Solljak
Hello,
For some reason only select FN buttons actually work, main one being the volume up button, volume down doesnt work, or volume off ect ect. Really need the page up and down buttons toi work too which don't unless i turn numock off, which is "workable" but not ideal
Does anyone know if this is an issue in general or am i missing a trick in the settings again?
Will post specs below
Solljak
AC Adaptor
1 x 230W AC Adaptor
Firefox™
Promotional Item
Welcome Book
Can you take a photo of your keyboard and upload it please?
Solljak
here you go
Solljak
another easy method to shrink images is in the photos viewer, you can click on the ... on top right corner and theres a resize setting :D
Agreed, but it doesn't give you the option to resize to a space size, only pixel ratio, so it's not very easy to work out. The default under 2Mb is only 0.25Mb which would be incredibly poor quality.
