Hi all.
I’m planning a build for flight sims (mainly DCS World) and would appreciate any advice on my build choices.
The world of gaming pc’s is new to me having only played consoles previously so it’s been a steep learning curve!
I’ll be playing on a 1080 monitor to start with but may upgrade this in the future as funds allow.
Also I’d like to keep the spend under £1700 if possible 👍
So here are my choices, what do you think?
CORSAIR CRYSTAL SERIES 280X RGB GAMING CASE
Intel® Core™ i5 Six Core Processor i5-10600K (4.1 GHz) 12 MB Cache
ASUS® ROG STRIX Z490-I GAMING (Mini-ITX, LGA1200, USB 3.2) - ARGB Ready
32GB Corsair VENGEANCE DDR4 3000MHz (2 x 16GB)
8GB NVIDIA GEFORCE RTX 3060 Ti - HDMI, DP
500GB Samsung 860 EVO 2.5" SSD, SATA 6Gb/s (up to 550MB/sR | 520MB/sW)
Noctua NH-C14S Ultra Quiet Performance CPU Cooler
GIGABIT LAN PORT + Wi-Fi
Standard Build - Approximately 23 to 25 working days
