Hello Pc Specialist.
I hope you can assist me as Im not very happy about this problem creeping up shortly after the 1 Year warranty period. This is the second problem Im having with this laptop, the other being a faulty Hard Drive which was replaced within warranty but I still had to pay for the delivery. My old laptop lasted me 5 years without any issues, so its very annoying that a highend laptop is starting to show signs after 1 year.
Anyway, now its a yellow hue/flickering sceen problem. At a certain angle, when the lid is opened to around 85-95 degrees from the keyboard, the screen experiences a yellow hue on the white colours. This is fixed by opening the lid wider than 95 degrees or closing it slightly under 85 degrees. At 90 degrees, it can temporarily be fixed by adjusting and holding the screen tightly but as soon as I let go, the annoying yellow hue is back. In addition to this hue, there is also a perfectly vertical yellow line, of the same colour as the hue.
I suspect a loose or worn cable but I dont see where it could be loose. Can you please assist. Surely this laptop should last more than 1 year of normal use.
I await your response
