Flash BIOS - unrestricted BIOS
bpr
Hello there,
as mentioned in the title I would like to flash the bios to have unrestricted access.
I know that I would lose the warranty and any technical support afterwards if I ran into problems.
However, due to the nature of my job I need to enable hard disk encryption (not via bitlocker!) and I need to have access to other features such as Virtualisation etc. Though I feel like the virtualisation is enabled.
The bios is an Aptio 2.15.1236 by American Megatrends Inc. - BIOS Version 4.6.5
The motherboard is an P15SM-A_SM1-A.
Any help would be greatly appreciated.
Thank you.
That would require a custom bios which only pcs or clevo would be able to do for you. I'd suggest giving pcs a call and asking them. These forums aren't monitored by pcs, so we won't be able to help unfortunately.
Edit: virtualisatuon is enabled by default.
Hello there,
Thank you.
I agree with SpyderTracks, only PCS or Clevo can help you with this (and I don't believe Clevo will talk to end users, they only deal with OEMs). I would not, under any circumstances, use a BIOS you might find from any other source. You risk not only voiding your warranty and loosing support but you also risk bricking the laptop and turning it into a lump of useless plastic.
