My brother is looking to buy his new pc but his budget is around £600.
It will mainly/only be used for gaming.
Can anyone recommend specs for him please?
InWIN G7 BRUSHED EFFECT DARK GREY CASE
AMD FX-6300 Six Core CPU (3.50GHz/8MB CACHE/AM3+)
ASUS® M5A97 LE R2.0 (DDR3, USB3.0, 6Gb/s)
8GB KINGSTON DUAL-DDR3 1600MHz (1 x 8GB)
2GB AMD RADEON™ R9 270X - DVI, HDMI, DP - DX® 11, Eyefinity 4 Capable
1st Hard Disk
STANDARD AMD CPU COOLER
When I click Ok at the bottom it gives me this message
Please note that due to the motherboard you have selected not having a USB 3.0 header, the USB 3.0 front ports on this case will not be active. If you would like the USB 3.0 ports to be functional, please select a different motherboard.
I tried the gigabyte motherboard but still gives the same message.
Would this be a majo
All its telling you is that the front USB ports on the computer case will not work (at least not as USB 3.0 ports) - Not a problem really, as long as you don't need to plug loads of USB's in Just a little less convenient for inserting memory sticks and the likes.
