First PC setup
ish
Hi guys, I got my system delivered to me yesterday, after some work setting it all up here it is.
Citrus_9
Expert
Hi guys, I got my system delivered to me yesterday, after some work setting it all up here it is. View attachment 26838View attachment 26839View attachment 26840View attachment 26841View attachment 26842
Beautiful! What are the specs? 🥸
Don't forget to screw in the wifi antennae if you got with wifi and repeatedly run all Windows 10 updates for the first few days. Also, check if your GPU drivers are installed and a monitor refresh rate is setup through Windows monitor advanced settings 👌
  • Like
Reactions: ish
AleTax
JediMonsoon
It doesn’t look like the rgb is working on the extra side mounted installed fans?
if you ordered the 5 extra fans instead of the 3 would they put one on the rear and would they just give the extra as a spare?
ish
When I tried to choose five the configurator displayed that the case does not have enough space for all the fans.
ish
